Questions Concerning BIOS T460s Passwords
  • poisonite
    • Nov 2019
    • 25
    • United States of America
    Hi there, Firstly thanks for reading, I've been searching through various threads and videos across the internet for the last little while and I was hoping that the wonderful folks here could help me answer some lingering questions I've got.
    So I have several laptops with BIOS passwords that I'm unable to remove conventionally (no good boot drive and backdoor password doesn't exist) like my Lenovo T460s for example. I've been looking into possibly flashing a clean version of the BIOS firmware from a machine that doesn't have a password (most likely one found here on the forums or elsewhere on the web) with the process shown in this video.
    https://www.youtube.com/watch?v=OttN8wQ1HhE
    So far I've heard differing things on whether a process like this where I write a new bios directly to the chip would solve the password issue, or if there's some other location I would need to flash.
    I'm hoping to have an answer for this T460s specifically as it's of the greatest importance to me but I'd also like to have the general knowledge as to what commonly works and what doesn't to remove these passwords so that I can apply it to other devices in the future.
    I was also wondering how to tell between a 24x and 25x bios chip and if there are other forms that I need to be aware of.
    Finally, while I'm not overly concerned with it, is there any chance of permanently bricking the bios chip as long as I copy the original firmware.bin to my system from the chip before any flash so that I may copy the original back later.
    Thanks for reading, I'm still a little new here so please let me know if I need to move this to another thread section or if I must break up my questions into separate posts.
    Any info is greatly appreciated, I feel very lost right now
    Last edited by SMDFlea; 09-15-2020, 08:56 AM. Reason: Renamed thread title,moved to laptop bios requests
    • 31187
    Re: Questions Concerning BIOS Passwords
    modern laptops dont keep the password in the bios - you wont get to it.
    the T460s though is doable.
    if you search the forum there is a special bios you can flash that will erase the password, then you re-flash the original backup back to the machine.
    • poisonite
      • Nov 2019
      • 25
      Ok I appreciate the info, do you know of a process I can use on newer machines?
      • poisonite
        • Nov 2019
        • 25
        Oh and another question I just thought of, I found this page which seems to have the patch for my laptop. However, the file is a .rom and not a .bin. How would I use that file with the external flash with the 8pin clips as show in the video on my first post?
        https://www.badcaps.net/forum/showth...highlight=t460
          • 31187
          just rename it, it's called .rom so winphlash and other software will see it
          remember 2 things.
          1: backup first,
          2: read the instructions.
          for example, there is often a security switch that detects if the covers are off - it must be held down.
          • poisonite
            • Nov 2019
            • 25
            Ok thanks, I’ll be sure to do all that when my programmer arrives.
            Would you mind sharing what is usually changed in a patched bios to allow it to erase the password, or perhaps point me in the right direction if there’s a guide somewhere on how that works?
            Also how will I know whether to use the 24x or 25x side of the programmer? Is this something I can find from the data sheet on the bios chip?
              • 31187
              you use the 25x side, because the part number starts with 25
              you can find a long thread on how the bios works,
              but the short version is that it contains an extra program in the EFI area that erases the password from the keyboard controller and then fixes the checksums in the TPM memory.
              • poisonite
                • Nov 2019
                • 25
                Ok I’ll have to give that a read, do you by chance have the link to that article?
                  • 31187
                  no, but it's from the same guy who posted the files in your link
                  • studdy05
                    Bricked HP Probook 450 G7 Bios questions
                    by studdy05
                    Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                    Ive got...
                    07-08-2025, 09:24 PM
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
                    Common SPI bios chip programming Questions and Answers
                    by SMDFlea
                    Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                    A: If you can`t read from it how do you expect to write to it ?.
                    Q: Why is my bios chip unreadable ?.
                    A: The programmer is faulty or has a worn or broken zif socket.
                    The USB cable is frayed,connector pins worn or some other physical damage.
                    Not enough amperage or voltage to power the programmer properly.
                    Bad...
                    09-02-2021, 04:40 PM
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
