Need UEFI Password Removed from my Surface Pro 5 BIOS DUMP
    Re: Need UEFI Password Removed from my Surface Pro 5 BIOS DUMP
    Originally posted by bafylu View Post
    hi surface pro 1796 bios password can someone help, thanks
    Read earlier posts .Download both attachments,open both with with a hex editor and do a file compare,there is only one change to make.
    The clue is AWORD
      attach file
        Could somebody help me about my Surface Pro 5 ?
        [ Microsoft Surface Pro 5 /M1796/ 4gb 128gb /
        I dumped bios from my not working chip on my Surface pro 5 ( whenever click power on, the winodws logo would last about 4 seconds, then screen goes to black), the dumped file size only 1Mb ( version 11.6..20.1221 by UFEITOOL). Said "No BIOS region section" when checked by UFEITOOL 0.28.0
        And I tried download biso 16Mb from the website (microsoft-surface-pro-5-m1007506-015-clear-me-bios, version 11.8.50.3448)), reflash to chip, pro5 is working properly in everything, but no touch function.
        Is there a way to fix touch function?
        Dumped BIOS and clear ME BIOS
        My dumped BIOS
          What did you use to make your backup.As it was getting to the windows logo there wasn`t much wrong with the bios. Its very important to make a good backup of the original bios,theres no way it would only be 1MB and boot to the windows logo.
          AFAIK theres no fix yet for the touch screen not working when you flash a different bios,i could be wrong though
            I used CH341A programmer to read after removed 25Q128FV-Winbond from PCB. And I used same tool to flash the downloaded BIOS to Chip, then solder bak on PCB.
              hello everyone I'm new to the forum please I need help I bought a surface pro 5 on ebay and it's blocked by uefi it doesn't have windows installed either.
              Can someone help me or give me a link to a tutorial. Thank you
              sorry for my bad English
                @abdielhdz
                The only way to unlock it is through the BIOS, it is necessary to post the file after reading.
                  hello thanks for answering
                  should I use any program? excuse my ignorance
                    @abdielhdz
                    The whole process is very simple, but it depends on opening the equipment and eprom programmer, tipo CH341A (low cost).
                      Can you tell me the steps to follow?
                      taking out the ssd disk and formatting it on another pc and then installing it on the surface could it let me install window?
                        @abdielhdz
                        It is not that simple, during the installation Windows is set to the machine's defaults.
                        The installation will probably be incompatible with another device.
                        It might even work if you had two identical laptops, i.e. of the same model.
                        It would be much easier to unlock the laptop.
                          I need to remove bios password of my surface pro 1796 . Here is the dump of the eeprom.
                          thanks
                            thanks
                            try
                            Become a Badcaps supporter
                            Thanks to all supporters.
                              Originally posted by hoaca388 View Post
                              try
                              @hoaca388
                              Check again, it won't work!
                                Ok , again
                                  try
                                  thanks. I am going to try and let you know the result .
                                  thnak you for your answer
                                    Ok , again
                                    So I am going to try this one first !
                                    thanks bro
                                      Originally posted by onizzbox View Post
                                      @hoaca388
                                      Thank you @onizzbox for your help !
                                        Ok , again
                                        Thank you, it works like a charm !
                                        Best regards.
                                          Originally posted by TranTrien View Post
                                          Hi friend , can you please tell me how did you backup bios file with CH314a . how did you connected it . or we have to take the EC out ?
                                          Thank you so much
                                          Hi Friend,
                                          I desoldered the IC. On thes chips I could not find an adapter that can connect while it is soldered to mainboard.
                                          Removed it from mainboard. Then soldered on connectivity board with low tempereture solder.
