toshiba l70-b-151 PSKS8E AR10SQG-6050A2640401 working bios dump
  • hasanaga_84
    • Jan 2020
    • 36
    • Türkiye
    needs download, it works.
    toshiba l70-b-151 psks8e working bios dump
    i7 4720hq cpu 8gb ram r9m200x gpu
    best regards.
  • cetincet
    • Jan 2014
    • 24
    • Turkey
    Re: toshiba l70-b-151 PSKS8E AR10SQG-6050A2640401 working bios dump
    Thanks i could kiss you.
    • coder78
      • Aug 2015
      • 67
      • turkey
      thanks
      • TyMercer
        Can I flash a working BIOS from one computer to another of the same make, model, etc?
        by TyMercer
        Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
        11-13-2025, 09:39 PM
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • haitham sharabati
        by haitham sharabati
        Hello engineers 😀,
        🔧 Device Info:
        - Model: HP 15-da2007ne
        - Product Number: 8XF55EA#ABV
        - Serial Number: CND0338P0D
        - CPU: Intel Celeron N4000
        💀 Problem:😅
        08-07-2025, 04:54 AM
      • DProf.
        TOSHIBA DYNABOOK T55/AB, PT55ABP-BJA2 BIOS DUMP
        by DProf.
        High great minds, please i need bios dump for this system .or help to REMOVE the PASSWORD in my original dump
        Toshiba Dynabook T55/AB, PT55ABP-BJA2
        MODEL NAME. Satellite L50-D series
        P[ART NO PS57MN-00600R
        Attached is my original bios dump ADMIN. PASSWORD LOCKED. Thank you in advance....
        09-26-2024, 04:30 AM
