UX305CA rev. 2.0 fix/clear
  • garfild
    • Aug 2020
    • 26
    • CZ
    hello there!
    after 2 weeks of measuring of my dead laptop I found your forum and some kind of the solution which you are doing in here.
    I saw that you are somehow able to fix image of the corrupted bios eeprom. Based on the previous topics it helped to completly same issue as I have (0V vcore,0V igpu, 0V buf_plt_rst, caps led on, no picture)
    I took out the eeprom and made image via flasher, could you please make you magic to fix dump?
    thanks a lot!
  • peste
    • Dec 2016
    • 12734
    • ROMANIA
    Re: UX305CA rev. 2.0 fix/clear
    Originally posted by garfild
    hello there!
    thanks a lot!
    try..
    • garfild
      • Aug 2020
      • 26
      • CZ
      hello sir,
      no change - still same issues - LEDs on, no picture, no vcore
      • peste
        • Dec 2016
        • 12734
        • ROMANIA
        hello sir,
        try..
        • garfild
          • Aug 2020
          • 26
          • CZ
          ok its alive! wow, thanks a lot! May I ask you what happend and what you did with the dump?
          thanks!
          • garfild
            • Aug 2020
            • 26
            • CZ
            Should I keep your version or force reflash stock version?
            Thank you
            • peste
              • Dec 2016
              • 12734
              • ROMANIA
              thanks!
              I combined the original bios of the laptop, with the update on the site, and I cleaned the ME region.
              • garfild
                • Aug 2020
                • 26
                • CZ
                So its a procedure desribed in "[TUTORIAL] fix asus bios with bios from asus web support" thread?
                • peste
                  • Dec 2016
                  • 12734
                  • ROMANIA
                  search the net for video tutorials on this topic ....
                  https://www.youtube.com/watch?v=CALZOeLV5kA
                  • SidneyCanadas
                    93C46 and 93C56 EEPROM
                    by SidneyCanadas
                    I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                    https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                    Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                    06-14-2023, 01:16 PM
                    ASUS ZenBook UX305CA-FC094T Notebook Specification for Upgrade or Repair
                    This specification for the ASUS ZenBook UX305CA-FC094T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX305CA-FC094T boardview and UX305CA-FC094T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-06-2024, 06:58 AM
                  • dmccul2698
                    Pioneer DEX-P99rs "No EEProm " diagnostic code.
                    by dmccul2698
                    Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
                    1). Understand the schematic and check the connections between the EEProm and DSP
                    2). Check the functionality of the EEProm
                    I don't know if this is the unit's problem but it's a place to start.
                    I have little to no electronic experience...
                    04-08-2024, 05:32 PM
                  • edgarmg15
                    Damaged EEPROM on TV Vizio E320-A0
                    by edgarmg15
                    Hi everyone
                    I´m trying to repair a TV Vizio E320-A0 that I found in the street
                    The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
                    The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
                    So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
                    11-19-2022, 03:46 PM
                  • KABY
                    dell 3542 IGPU disable
                    by KABY
                    hello I'm looking for some answerer about IGPU
                    i have dell 3542 with IGPU AND DEDECATE one
                    the mane IGPU its not working properly every time i boot up i get some artifacts and laptop turn of and reboot again some time it boot normally for 1 min and the same scenario again artifacts and shutdown
                    my question!
                    is it possible to disable IGPU and run laptop with DGPU
                    or there is any possibility to disable it via bios bin or take off some capacitor or coil like DGPU to disable it completely
                    thanks for your accept and answer
                    bios bin added and schematic...
                    10-06-2023, 05:55 AM
