Requesting HP ZBook 15u G3 6050A2892401-MB-A01 EC and Bios
  • Zibbo
    • Mar 2017
    • 203
    • Zimbabwe
    I have a HP ZBook 15u G3 board number 6050A2892401-MB-A01 that will not turn ON. I was able to read the main bios but the EC bios chip is completely unreadable.
    Does anyone have a matching file? Thank you
  • peste
    • 12859
    • ROMANIA
    Re: Requesting HP ZBook 15u G3 6050A2892401-MB-A01 EC Bios
    try..
    https://www.alisaler.com/hp-eliteboo...1-mb-a01-bios/
    • Zibbo
      • Mar 2017
      • 203
      • Zimbabwe
      Thanks but not working
        • 20990
        Post your main bios .
        • Zibbo
          • Mar 2017
          • 203
          • Zimbabwe
          Here is the main backup
          • peste
            • 12859
            • ROMANIA
            try..
            • Zibbo
              • Mar 2017
              • 203
              • Zimbabwe
              Originally posted by peste
              try..
              Working...thank you so much!
              • Stuki
                • Apr 2012
                • 9
                • Greece
                Which is the main bios chip? I mean the number of chip.
                Thanks.
                • Twsti
                  • Nov 2023
                  • 9
                  I have made some mistakes. I got the laptop for free and there was a password in the bios. So I tried my luck. I bought a CH341A and don't ask how. But I accidentally read the IC chip W25Q128JVIQ and made a backup of it and tried to unlock it. Then I realized that the password is not saved on it. I also have a backup of that.
                  I SOMEHOW damaged the other bios chip. It can't be read or written.
                  I then bought the same defective laptop for $20.
                  But I realized that the motherboard is not the same. I also got confused with the chip. I don't remember if it's a W25Q128JVPQ or a W25Q128FVPQ.
                  My guess is a W25Q128JVPQ.
                  Now I have soldered the W25Q64JVIQ back on. And loaded the bios from the other defective laptop onto the W25Q128JVPQ and also soldered it on. Now I have the problem that the laptop doesn't start anymore. CAPS Lock is on.
                  If I remove the battery, the laptop turns on, has a black screen, and the fan spins.
                  Laptop: zBook 15u G3
                  Mainboard: 839235-601
                  Bios Chip: W25Q128JVPQ
                  If someone has the same laptop. Is the Bios chip correct?​
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11798
                    Post bios backup and serial number.
                    • Twsti
                      • Nov 2023
                      • 9
                      I have only the Bios Backup from the other Laptop.
                      My Mainboard: 839235-601
                      My Serial: 5CG8174XGV
                      The Laptop from the Backup has the Mainboard: 918325-601
                        • 20990
                        Look on the motherboard for a part number similar or the same as 6050A2892401-MB-A01 ,post it.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11798
                          HP ZBook 15u G3 Mobile Workstation
                          • Twsti
                            • Nov 2023
                            • 9
                            Hello my friend,
                            its 6050A2892401-MB-A01
                              SMDFlea commented
                              Editing a comment
                              Merged your posts with an existing thread topic
                          • Twsti
                            • Nov 2023
                            • 9
                            Can i use any Bios firmware that has the same motherboard?
                              SMDFlea commented
                              Editing a comment
                              If its an intel board not without cleaning the ME firmware first, and your DMI info will be messed up and you`ll have to enter it all again using HP`s shitty DMI tools (unless it does a bios recovery and restores it itself). Try the bios posted by hoaca388
                          • Twsti
                            • Nov 2023
                            • 9
                            Is it difficult or complicated to edit the DMI information? I am relatively familiar with software and everything. I can quickly familiarize myself with everything.
                            I also have an Intel. I'll try the BIOS above later. Thank you very much​
                              SMDFlea commented
                              Editing a comment
                              The HP DMI tools are relatively easy to use once you get used to using them but if its the first time then it can be a real headache.
                          • Twsti
                            • Nov 2023
                            • 9
                            Do I need another program besides DMI Tools from HP?
                            • EbrahimSiami
                              Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                              by EbrahimSiami
                              I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                              **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                              **What I have tried so far:**
                              1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                              07-02-2025, 02:31 PM
                            • macabook
                              by macabook
                              🧩 Initial Issue
                              07-24-2025, 02:17 PM
                            • TripTop
                              Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                              by TripTop
                              Hi
                              i have dell latitude E7270 with following symptoms:
                              - takes long time to restart.
                              - sometimes powers on and then off
                              - sometimes while working it just dies,
                              From googling online bios clean could possible resolve this?
                              i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                              As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                              I reinstall...
                              09-09-2024, 02:05 PM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • zenius
                              by zenius
                              12-08-2024, 06:13 AM
