Hello guys !
I've buy a second hand T480 .. like many peoples here the computer has a Supervisor Password set. And the seller ignore what could be the password.
I've read carefully the instructions and ordered a CH341A. Now i'm studying the answers on the forum after the main post.
I would like to clarify, if the Step 8 "Restore original BIOS" mean restore the binary dumped in Step 1 ?[ HOW TO USE THE PATCH ]
STEP 1: Flash and replace current BIOS with the generated patch file
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter any character when asked for Supervisor Password
STEP 5: Press enter when it shows Hardware ID
STEP 6: Press space bar 2x when asked
STEP 7: Turn off machine
STEP 8: Restore original BIOS
STEP 9: Reset BIOS settings to factory default
Thank's you !Comment
Yes, it is referring to the dump created in Step 1.Hello guys !
Thank's you !
As a precautionary move, create AT LEAST 2 GOOD IDENTICAL DUMPS.. you can use Beyond Compare software to open 2 dumps side-by-side for comparison that is what i used aside from HxD. Any small differences in the file is highlighted right away..
This is crucial because there are others who unfortunately had problems in restoring the laptop to its working state after a failed patch despite using the dump they made in Step 1.Comment
Try this .....Attached Filesif you find these attachements useful please consider making a small donation to the site
Thank's you for the precision, yes i have well undertood the important place take that dump, i will do at least 3 to be safe and check them carrefully !Yes, it is referring to the dump created in Step 1.
I've done the 3.3v mod on my CH341A received this morning.
A did some test with flashrom on my spare hackintosh but got some errors, look due to the software ecosystem, so i will retry from ubuntu on liveusb..
So i booted on a LiveUSB of Ubuntu 22 and installed Flashrom 1.2 from repo.➜ ~ flashrom -p ch341a_spi -r test.img
flashrom v1.2 on Darwin 19.6.0 (x86_64)
flashrom is free software, get the source code at https://flashrom.org
Calibrating delay loop... OK.
Couldn't open device 1a86:5512.
Error: Programmer initialization failed.
the CH341A is well recognized in the output of lsusb.
but i got this result when i type this command :
Also sometime the CH341A does not appear in lsusb output when clamped to the BIOS chip.cb_in: error: LIBUSB_TRANSFER_TIMED_OUT
ch341a_spi_spi_send_command: Failed to write 37 bytes
cb_out: error: LIBUSB_TRANSFER_TIMED_OUT
Does someone knew why ?Last edited by HiddenTTY; 08-30-2022, 06:40 AM.Comment
I've resolved the issue, the 3.3v fix made the whole module not work properly.. after i undo the mod all worked well !
So i would like to thank's all the people behind this pretty work !Comment
Hi, i'm trying to patch Lenovo ThinkPad T490 20N3-S2KS03 with i7 8th gen vpro but i get this error. Is there any way to patch? Attached is the dump. Thanks
Code:Using UEFIReplace to inject 2 DXE drivers... [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5) [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd) Looking for volumes to patch... [1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h): Not found... Skipping. Done.
I'm not sure if anyone is following this Thread. But I'm stuck like many. The autopatcher isn't working on my computer. It starts then crashes. I've attached my bios dump for a P53s. If someone could patch i would be very greatful.Last edited by SMDFlea; 03-25-2023, 11:57 AM.Comment
You are stuck like many for the exact same reason - failed to read the dump properly.
But doesnt matter too much because autopatcher is unable to unlock P53s anyway. You need svod3, rt809 or vertyanov to read/write MEC chip instead.Comment
Do you have a list of others, up to 8th gen that can`t be patched.It would be handy to add the list to the first postComment
Your dump file seems to be invalid.Attached Filesif you find these attachements useful please consider making a small donation to the site
I had similar result but a patched bin is created anyway.Hi, i'm trying to patch Lenovo ThinkPad T490 20N3-S2KS03 with i7 8th gen vpro but i get this error. Is there any way to patch? Attached is the dump. Thanks
Code:C:\Users\Lenovo\Downloads\lenovo_autopatcher_0.2\lenovo_autopatcher>autopatch T490.bin Using UEFIReplace to inject 2 DXE drivers... [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5) [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd) Looking for volumes to patch... [1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h): Not found... Skipping. Done. PATCH FILE: T490_PATCHED.bin Good luck.
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by piratiHello everyone,
Product ID: RZ09-0421
Motherboard: CH580
Bios File Size: 32,768 KB
Dear Forum Readers!
!!! MY RAZER BLADE...-
11-24-2025, 05:52 PM -
- Loading...
