  • corona100
    • Mar 2020
    • 155
    • U.S.A
    #1801
    Originally posted by hoaca388
    Here.
    thank's but after flash this dump no power
    • parhatskiy
      • Aug 2016
      • 28
      • ukraine
      #1802
      model Lenovo ThinkPad X13 Yoga Gen 1, MB: LBB-2 19733-1
      I ask for help! patch bios please!
      • parhatskiy
        • Aug 2016
        • 28
        • ukraine
        #1803
        ec dump old
        • HiddenTTY
          • Aug 2022
          • FRANCE
          #1804
          Hello guys !
          I've buy a second hand T480 .. like many peoples here the computer has a Supervisor Password set. And the seller ignore what could be the password.
          I've read carefully the instructions and ordered a CH341A. Now i'm studying the answers on the forum after the main post.
          [ HOW TO USE THE PATCH ]
          STEP 1: Flash and replace current BIOS with the generated patch file
          STEP 2: Boot the machine
          STEP 3: Press ENTER/F1/etc. to enter BIOS settings
          STEP 4: Enter any character when asked for Supervisor Password
          STEP 5: Press enter when it shows Hardware ID
          STEP 6: Press space bar 2x when asked
          STEP 7: Turn off machine
          STEP 8: Restore original BIOS
          STEP 9: Reset BIOS settings to factory default
          I would like to clarify, if the Step 8 "Restore original BIOS" mean restore the binary dumped in Step 1 ?
          Thank's you !
          • fr0stbit3
            • May 2011
            #1805
            Originally posted by HiddenTTY
            Hello guys !
            Thank's you !
            Yes, it is referring to the dump created in Step 1.
            As a precautionary move, create AT LEAST 2 GOOD IDENTICAL DUMPS.. you can use Beyond Compare software to open 2 dumps side-by-side for comparison that is what i used aside from HxD. Any small differences in the file is highlighted right away..
            This is crucial because there are others who unfortunately had problems in restoring the laptop to its working state after a failed patch despite using the dump they made in Step 1.
            • Ruslan2017
              • Nov 2017
              • 8
              • Великобритания
              #1806
              Good Day .
              Please Can any one help me to pah Lenovo L14 bios .
              using autopatcher i'm having problems
              Thank you
              • orik
                • Aug 2022
                • Ukraine
                #1807
                Please help me make a patch for this dump. I don't want to run autopatch.cmd
                • orik
                  • Aug 2022
                  • Ukraine
                  #1808
                  do not work*
                  • Markus1741
                    • Sep 2020
                    • 975
                    • N/A
                    #1809
                    do not work*
                    Try this .....
                    • HiddenTTY
                      • Aug 2022
                      • FRANCE
                      #1810
                      Thank's you for the precision, yes i have well undertood the important place take that dump, i will do at least 3 to be safe and check them carrefully !
                      I've done the 3.3v mod on my CH341A received this morning.
                      A did some test with flashrom on my spare hackintosh but got some errors, look due to the software ecosystem, so i will retry from ubuntu on liveusb..
                      ➜ ~ flashrom -p ch341a_spi -r test.img
                      flashrom v1.2 on Darwin 19.6.0 (x86_64)
                      flashrom is free software, get the source code at https://flashrom.org
                      Calibrating delay loop... OK.
                      Couldn't open device 1a86:5512.
                      Error: Programmer initialization failed.
                      So i booted on a LiveUSB of Ubuntu 22 and installed Flashrom 1.2 from repo.
                      the CH341A is well recognized in the output of lsusb.
                      but i got this result when i type this command :
                      cb_in: error: LIBUSB_TRANSFER_TIMED_OUT
                      ch341a_spi_spi_send_command: Failed to write 37 bytes
                      cb_out: error: LIBUSB_TRANSFER_TIMED_OUT
                      Also sometime the CH341A does not appear in lsusb output when clamped to the BIOS chip.
                      Does someone knew why ?
                      • lashamafia
                        • Nov 2017
                        • 22
                        • georgia
                        #1811
                        hello please patch this bios for me
                          • 22206
                          Desolder the chip if you can, or try using the CH341A with a powered USB hub
                          • HiddenTTY
                            • Aug 2022
                            • FRANCE
                            #1813
                            I've resolved the issue, the 3.3v fix made the whole module not work properly.. after i undo the mod all worked well !
                            So i would like to thank's all the people behind this pretty work !
                            • DanqeR
                              • Oct 2014
                              • 6
                              #1814
                              Hi, i'm trying to patch Lenovo ThinkPad T490 20N3-S2KS03 with i7 8th gen vpro but i get this error. Is there any way to patch? Attached is the dump. Thanks
                              Code:
                              Using UEFIReplace to inject 2 DXE drivers...
                              [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
                              [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
                              Looking for volumes to patch...
                              [1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h):
                                 Not found... Skipping.
                              Done.
                              • MMbacon
                                • Feb 2022
                                • canada
                                #1815
                                I'm not sure if anyone is following this Thread. But I'm stuck like many. The autopatcher isn't working on my computer. It starts then crashes. I've attached my bios dump for a P53s. If someone could patch i would be very greatful.
                                • RethoricalCheese
                                  • Mar 2013
                                  • 1519
                                  • Estonia
                                  #1816
                                  You are stuck like many for the exact same reason - failed to read the dump properly.
                                  But doesnt matter too much because autopatcher is unable to unlock P53s anyway. You need svod3, rt809 or vertyanov to read/write MEC chip instead.
                                    • 22206
                                    Do you have a list of others, up to 8th gen that can`t be patched.It would be handy to add the list to the first post
                                    • rednax
                                      • Aug 2022
                                      • Philippines
                                      #1818
                                      Your dump file seems to be invalid.
                                      • rednax
                                        • Aug 2022
                                        • Philippines
                                        #1819
                                        Code:
                                        Done.
                                        I had similar result but a patched bin is created anyway.
                                        Code:
                                        C:\Users\Lenovo\Downloads\lenovo_autopatcher_0.2\lenovo_autopatcher>autopatch T490.bin
                                        Done.
                                        PATCH FILE: T490_PATCHED.bin
                                        Good luck.
                                        • husnu16
                                          • Jun 2020
                                          • 123
                                          • Türkiye
                                          #1820
                                          Originally posted by N0f3ar
                                          hi , can somebody help with bios pass lenovo ideapad 3
                                          hello master, I have uploaded your bios to my computer, but there is a password. Can you share the password for this bios?
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
