Thanks to everyone involved. I just needed to patch 4mb file (although I took backup of other 8 mb chip as well, but that wasn't needed). I used colibri ch341 programmer and found to be more reliable and accurate in detecting chips.Comment
Attached FilesComment
i am trying to unlock my t470s bios, when I drag my bios bin in autopacther a quick command opens and closes whereas no patch file is created.
help will be appreciated.Comment
Hi that worked perfectly, just wondering how you managed to do it, I have the lenovo auto patcher but it didn't work with me and frooze while patching, do you reckon we have the same software or a like to the software you used to unlock it?Comment
What operating system are you using?Comment
It will give an output of the bios I'm patching but the patched bios contents matches up to the original dump.
using lenovo autopatcher on ubuntu 20.04.2 LTSComment
I have set up a machine with ubuntu on it and im now getting this error, just wondering if i'm typing it correctly or if I'm missing something.
The reason is simple, the UEFIReplace file cannot be executed.
You need to run chmod +x /Path/TO/tools/UEFIReplace.
Or so
SHOW=$(sudo find $HOME -iname UEFIReplace); echo $SHOW
SHOW=$(sudo find $HOME -iname UEFIReplace); chmod +x $SHOW
SHOW=$(sudo find /media/ -iname UEFIReplace); chmod +x $SHOWLast edited by Markus1741; 06-09-2021, 08:18 AM.Comment
This also happened to me in the beginning.
Or so
Ive done this now and now getting a different message, I've tried two different dumps of the same make and model as before (the original one you did for me and an original one of a second machine) and both come up with this message.
Please see screenshots, I've included one of the terminal output and one of the folder location where its pointing.
My theory is that its trying to open the UEFIReplace.exe but I've also tried it on windows 10 and this is still the same output.Comment
Hello, I can already see the problem.
It is important to either use the absolute path like this.
python3 $HOME/Desktop/lenovo_autopatcher/patch/autopatch.py $HOME/Desktop/lenovo_autopatcher/patch/Left1st.BIN
Or you are rich in the same folder than like this
python3 autopatch.py Left1st.BIN
Even what does not work in UNIX systems is insufficient information, the system cannot add it itself.
sudo python3 autopatch Left1st is not correct.
python3 autopatch.py Left1st.BIN is correct.
Good luck!!Comment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by piratiHello everyone,
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
