Attached FilesComment
Try this, maybe work. If you can entering bios menu without entering password, then follow instructions on post 1 from inside the bios setup security menu. Don't forget to clear every security & fingerprintAttached FilesComment
Because your chip with 8MB cannot be patched.
https://www.allservice.ro/forum/images/T540p_bios.jpgLast edited by Markus1741; 04-06-2021, 11:33 PM.Comment
Hi, you can try this.
Patched with Autopatcher!Comment
thank you so much. but it not work. no display on, sound beep coming.Comment
@black0hackers: Try this patch and report results, instructions included.Attached FilesComment
FYI:
I destroyed the diode D12 while updating the chip of my T450, because I first connected the adapter wrong.
If your laptop does not turn on anymore (screen stays black and fan turns on briefly) then check the diodeComment
Hello.
Can anyone please help me?
Lenovo W530 (Kendo-4 platform), the password is in the BIOS.
an attempt to use a patch from a starttopic results in a patcher error.
D:\L>autopatch.cmd 4.bin
Using UEFIReplace to inject 2 DXE drivers...
[1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
4.bin is corrupted or does not contain a valid dump.
There was an error... Aborting.
D:\L>autopatch.cmd 5.bin
[2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
Looking for volumes to patch...
[1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h):
Not found... Skipping.
Done.
PATCH FILE: 5_PATCHED.bin
Good luck.Last edited by SMDFlea; 03-25-2023, 11:57 AM.Comment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
