    • 22099
    Originally posted by HARAN963
    Unlock
    See post 496 ,it was patched for you .
    • GKLMOBIL
      • Mar 2021
      • lp
      #502
      Unlock plesh t460
      • HARAN963
        • Mar 2021
        • 45
        • FRANCE
        #503
        Pls unlock
        • HARAN963
          • Mar 2021
          • 45
          • FRANCE
          #504
          Originally posted by smdflea
          see post 496 ,it was patched for you .
          where 496 page
          • Markus1741
            • Sep 2020
            • 965
            • N/A
            #505
            Originally posted by GKLMOBIL
            Unlock plesh t460
            Hi try this!
            • Markus1741
              • Sep 2020
              • 965
              • N/A
              #506
              where 496 page
              Hello please look on sitepage 25 (bar above) on the right side is the number with #496
              From New Member Ferrum
              • HARAN963
                • Mar 2021
                • 45
                • FRANCE
                #507
                Originally posted by markus1741
                hello please look on sitepage 25 (bar above) on the right side is the number with #496
                from new member ferrum
                tht is not work
                • Markus1741
                  • Sep 2020
                  • 965
                  • N/A
                  #508
                  tht is not work
                  Two things possible your original file is not correct (big problem) or I would reassemble the bottom case and try again.
                  • HARAN963
                    • Mar 2021
                    • 45
                    • FRANCE
                    #509
                    two things possible your original file is not correct (big problem) or i would reassemble the bottom case and try again.
                    rebackup bin and resent ok
                    • HARAN963
                      • Mar 2021
                      • 45
                      • FRANCE
                      #510
                      [QUOTE=Markus1741;1035640]Two things possible your original file is not correct (big problem) or I would reassemble the bottom case and try again.
                      • banane
                        • Mar 2021
                        • 6
                        EDIT: I got it running, exactly like described in Post #1 :-)
                        But the W25Q128FV needs to be erased before each programming step.
                        Many thanks !!!
                        Hi everyboy,
                        can someone help me with my T460p Laptop - Type 20FW ?
                        I backuped the original Bios and used the autopatcher but now the screen doesn't even turn on anymore.
                        orig.bin
                        SHA1: 98c542daec2de04d50a19620583c8cdc7018479e
                        IC says 250128FVSQ-1643, I took the W25Q128FV-Settings in AsProgrammer.
                        Help would be very appreciated.
                        Thanks and Greetings from Hamburg,Germany,
                        Banane
                        • Markus1741
                          • Sep 2020
                          • 965
                          • N/A
                          #512
                          Many thanks !!!
                          Hi everyboy,
                          orig.bin
                          Banane
                          Maybe you could try this!
                          • mielta
                            • Apr 2015
                            • 368
                            Hello
                            I have an X390 Yoga and i have patched Bios but it dont work
                            Black screen und peeps.
                            I send orginal Bios please Patch for me
                              • 22099
                              Originally posted by mielta
                              Hello
                              It can`t be patched,at the moment only allservice can do it in-house https://www.allservice.ro/forum/viewtopic.php?t=3044
                              • mielta
                                • Apr 2015
                                • 368
                                OK
                                Thanks for information
                                • AAAC
                                  • Jan 2020
                                  • 459
                                  • Mexico
                                  #516
                                  Hello
                                  Or if you have an EC/KBC programmer you can READ, ERASE and PROGRAM EC/KBC, disconnect all source of energy for 1-2 minutes, then reconnect and use Lenovo Maintenance Utilities (UEFI version) to enter Model Number, Serial Number and other data.
                                  As far as I know ThinkPad X390 has NUVOTON embedded controller, so you may be able to program it using keyboard connector on motherboard.
                                  • rashmignanesh
                                    • Jun 2020
                                    • 14
                                    • US
                                    #517
                                    Sir pls upload dell bios factory reset patch (blank & model)
                                    • black0hackers
                                      • Jul 2020
                                      • 369
                                      need clear bios pass Thinkpad P1 gen2 i7 9th
                                      • HARAN963
                                        • Mar 2021
                                        • 45
                                        • FRANCE
                                        #519
                                        Pls unlock
                                        • Markus1741
                                          • Sep 2020
                                          • 965
                                          • N/A
                                          #520
                                          Pls unlock
                                          Try this ...
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            Yesterday, 04:04 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
