Unfortunately, the autopatcher is not working for my Lenovo P50. I tried the old and the new ones as well. If I flash the patched version, there's no picture at all, but if I flash back my original backup, there's a normal boot, but the password is obviously there.
Can you help me patch this machine somehow? I'm attaching my original, working bios bin. This model has a Winbond 25Q128FV BIOS chip. I tried to flash similar BIOS bins from this topic, but none of them gave a picture.
Type 20EQ-S28U03
S/N: PC-0EQPM 16/08
Thank you in advance!Attached FilesComment
Hello all,
Posted before but looking back I see probably in the wrong thread.
I have been battling for a while trying to fix this bios but for some reason I am failing at the patching stage. Been trying the autopatcher but while it creates a patched file it just hangs with no results shown.
The laptop details are:
Lenovo Thinkpad L380
I5 Generation 8
Model : 20M6S1VV00
Serial number: W1KS89C10HD
I would like this laptop to have a few more years of being useful but have almost given up on it.
Many thanks for any help.Attached FilesComment
Hello friends!
I trying lenovo_autopatcher_0.2 with my laptop Lenovo x280 board NM-B521 s/n: PC10YNRJ.
patcher log is here:Using UEFIReplace to inject 2 DXE drivers...
[1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
[2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
Looking for volumes to patch...
[1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h):
Found volume at offset 800000h (checksum 2609h)
Replacing volume.
Done.
flashing patched bios, but laptop turn on with no display with beep code 0285.
please help me
i found over internet bios with clean_me, patched it, burn chip, remove password, burn my original bios and got super laptop (without pass)Comment
I tried the nokey version again, but exactly the same as the others. No picture.
If I flash back my original bin, it works perfectly, but I can't boot because of the SVP.Comment
Excuse me, does anyone have the x280 patch? Thank you for your attention.Attached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
dear Maxpower3 can you help me solve the problem of locked bios type x280, I didn't find anything that worked, S/N :PC0XVCCK
or try
https://www.badcaps.net/forum/troubl...16#post3738316Attached FilesLast edited by Maxpower3; Yesterday, 05:51 AM.Comment
Guys, listen up, I have an issue. I'm trying to use patcher 0.2 on a Lenovo E959 20NF. I have 2 of them, and of course, they have a BIOS password. When I dump the BIOS and use the patcher, after flashing the patched BIOS, the laptop doesn't boot. I thought I was loading something incorrectly, but when I flash the original image back, the computer starts up fine. This model (E959 20NF) is listed as supported. Could someone shed some light on my problem? I would be eternally grateful.Attached FilesComment
A hash value in your patched file needs to be changed. I've already done that here, but you should follow the rules and post the serial number.
Then I can give you the new patch file.Comment
It's actually quite simple: you have an AMD CPU laptop, and the auto-patcher was written for an Intel CPU.
I'm providing the system-unit serial number PF1Q99TA
Did you use Lenovo autopatcher 0.2 for patching?
Is there any chance you could instruct me on which value needs to be changed?Comment
Look at this video ....
https://www.youtube.com/watch?v=3BB--9VU0R0Attached FilesComment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
