Acer TravelMate P273-m bios
  • fyzeler
    • Aug 2020
    • 26
    • Holland
    I've somehow bricked the laptop by flashing from 2.03 to 2.11. All went smooth but after reboot it's not working anymore.
    fn + esc to force recovery from usb does not work.
    I took the motherboard out and want to flash the chip with ch341a programmer and a clip.
    The chip is Windbond 25Q16CVSIG = 16 megabit = 2 MB. The Acer bios that are downloadable .FD are 4MB or bigger??
    So I need a Dump from a 2 MB bios file, preferably 2.03 (model name BA70_HC).
    The full name is Acer Travelmate P273-M-32344G32Mnks with mainboard VA70/VG70 REV 2.1
    Really hope someone can extract the right size BIOS from the downloadable bios or someone has a dump of a machine which has the right bios.
    Will be grateful for the help.
  • peste
    • Dec 2016
    • 12792
    • ROMANIA
    Re: Acer TravelMate P273-m bios
    post the original bios here
    • fyzeler
      • Aug 2020
      • 26
      • Holland
      I have the original 2.03 that I downloaded. It's not a dump from the laptop, this is a .FD file which is for the rescue usb.
      In the download there is also the same file which is .rom and a .me file
      But I will post the .fd file, if you need more let me know.
      • fyzeler
        • Aug 2020
        • 26
        • Holland
        Here is the dump I make just now with the clip on the bios chip. This is the failing bios..
        I do not know which it is now, it should be the 2.11, but not sure.
        • fyzeler
          • Aug 2020
          • 26
          • Holland
          Hope somebody can help, 2.03 version is preferable because on that version the laptop worked. But I can also try a later version, as long the laptop will run, thats the most important thing.
          Maybe someone can also see what is wrong with the dumped bios, did flashing go wrong or something else. Im curious about that. I have no clue how to see that.
          • lapfix
            • Mar 2020
            • 2720
            • my workshop
            Better is to desoldered the bios and not use a clip .
            What's your serial number !
            • fyzeler
              • Aug 2020
              • 26
              • Holland
              I'm not sure which one is the serial number.
              Not using a clip, because the dumped bios makes no sense? Maybe the flashing went wrong and it's like that to begin with when I went from 2.03 to 2.11
              • fyzeler
                • Aug 2020
                • 26
                • Holland
                here is a picture of the numbers.
                • peste
                  • Dec 2016
                  • 12792
                  • ROMANIA
                  have you tried this ???
                  https://www.badcaps.net/forum/showthread.php?t=43952
                  • fyzeler
                    • Aug 2020
                    • 26
                    • Holland
                    Have not tried, compatible?? Also in the zip there, the one that is 2mb says hub.bin and the 4 mb one says KBC. What does it mean?
                    My chip can hold only 16mbit = 2MB. The only one I could flash is the Old v3-771g_HUB.bin
                    You think I should flash that one and see ?
                    • peste
                      • Dec 2016
                      • 12792
                      • ROMANIA
                      Do you have two bios chips on the motherboard? ... one with a 4mb bios and one with a 2mb ... check if you have two bios chips ...
                      • fyzeler
                        • Aug 2020
                        • 26
                        • Holland
                        Oh wow, you are right. There is another chip on the backside of the motherboard!!
                        Im so noob.
                        The one on the backside says. 25Q32BVSIG.
                        This mean this one is 32mbit, this means I can flash the 4mb rom?? I mean even the official one in the 2.03 of my laptop.
                        Can you explain what the other chip is that is 2mb? Is that KBC mean for start computer and LED lights etc? I shouldn't flash that one correct?
                        Because my laptop still can start and have led on, also fan is running. Just screen black no boot.
                        • peste
                          • Dec 2016
                          • 12792
                          • ROMANIA
                          make copies of both chips and post .... be careful not to confuse them ..
                          • fyzeler
                            • Aug 2020
                            • 26
                            • Holland
                            It seems I get different HEX outcome everytime i read that chip, what does this mean.
                            When I read the 2MB chip, the result is always the same. So my clip is no problem. When I read the 32mbit chip that i just found, 25Q32BVSIG it gives me a different HEX outcome all the time.
                            Does this mean this chip fail, the clip cannot connect proper or the chip maybe needs the motherboard to have power from power supply?
                            I used CH341A programmer 1.34 and ASprogrammer, everytime i read out the chip it gives different hex result. I Don't get it.
                            • fyzeler
                              • Aug 2020
                              • 26
                              • Holland
                              I've tried now with power supply on the mainboard, still same problem. What else could it be.
                              • lapfix
                                • Mar 2020
                                • 2720
                                • my workshop
                                As peste said : make copies of both chips and post .... be careful not to confuse them ..
                                You find your serial number on back of your lap .
                                • fyzeler
                                  • Aug 2020
                                  • 26
                                  • Holland
                                  Yes but I have problem reading the 4 MB bios chip from the motherboard. It give a different dump everytime i make a dump / read.
                                  The 2 MB chip is always the same dump, the 4 MB bios chip 25Q32BVSIG gives a different dump every read.
                                  This cannot then be trusted, the dump is no good. I have no idea how to fix it. As I said above I already tried with power supply, no change.
                                  The dump file is different still everytime I do a dump / read and is gibberish. Any idea?
                                  With the Ch341a programmer by detect I get also no brand, it supposed to be Winbond, does not give a brand. Every time auto detect it sometimes said cannot find chip and sometimes can read something.
                                  What is the problem, don't get it. It work fine with the 2MB bios.
                                  • lapfix
                                    • Mar 2020
                                    • 2720
                                    • my workshop
                                    give your serial number to try to give you another bios dump....for sure you must use another bios chip
                                    • fyzeler
                                      • Aug 2020
                                      • 26
                                      • Holland
                                      S/n: NXV87EH008307025AD7200
                                      snid: 30700964572
                                      You think the bios chip is no good anymore?
                                        • 20894
                                        Post 2 of the corrupt 4MB bios backups,your DMI info might be readable to copy to a clean bios.
                                          Acer TravelMate TravelMate Spin P4 Hybrid (2-in-1) Spin P4 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate TravelMate Spin P4 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TravelMate Spin P4 boardview and TravelMate Spin P4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 05:20 AM
                                          Acer TravelMate TravelMate Spin B3 TMB311RN-31-C7XH Notebook Spin B3 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate TravelMate Spin B3 TMB311RN-31-C7XH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TravelMate Spin B3 TMB311RN-31-C7XH boardview and TravelMate Spin B3 TMB311RN-31-C7XH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          Acer TravelMate TravelMate B3 (TMB311-31-C11C) Notebook B3 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate TravelMate B3 (TMB311-31-C11C) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TravelMate B3 (TMB311-31-C11C) boardview and TravelMate B3 (TMB311-31-C11C) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          Acer TravelMate TravelMate P2 TMP215-53-59TB Notebook P2 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate TravelMate P2 TMP215-53-59TB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TravelMate P2 TMP215-53-59TB boardview and TravelMate P2 TMP215-53-59TB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          Acer TravelMate TravelMate P6 TMP614-52 Netbook P6 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate TravelMate P6 TMP614-52 Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TravelMate P6 TMP614-52 boardview and TravelMate P6 TMP614-52 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
