Acer TravelMate P273-m bios
  • fyzeler
    • Aug 2020
    • 26
    • Holland
    Re: Acer TravelMate P273-m bios
    Okay, but it's like gibberish..
      • 22275
      ok so you`ll have to desolder the bios,then solder it to an adapter and try another backup .If it doesn`t read ok the chip is bad.
      • fyzeler
        • Aug 2020
        • 26
        • Holland
        Ok, will do that tomorrow. Will update after i soldered the bios to the adapter and have a bios dump.
        • fyzeler
          • Aug 2020
          • 26
          • Holland
          I've dumped a correct one now I think. I desoldered the chip and soldered to the adapter. I have compared the dump with the v2.03 I downloaded and they match 99%. There is a little difference but definitely there are parts different. Perhaps This dump is the 2.11 one, I can't see. But when I flashed the computer the first time the normale way from 2.03 to 2.11 it did go to 100% and give no fault that the flash had failed.
          Curious what you think is going on? Bios Corrupt or what I wonder.
          /edit/
          I found this in the dump
          D:\code\BA70\BA70.211_2\Project\Pegatron\OBJS\PDB\SecCore.pdd
          So it is version 2.11..
          So isn't it I just have to program 2.03 and it should work? But when I first updated from 2.03 to 2.11 when the laptop still work the flash screen said it also updated the EC bios. So what to do about that?
          • fyzeler
            • Aug 2020
            • 26
            • Holland
            Question, the stock bios does not have any info like the serial number of the laptop and stuff like that.
            Is it necessary to add these to the stock bios or will the laptop run without filling these things in?
            I want to flash v2.03 back in but it is of course not a backup or a dump, it is a stock bios from Acer, will the laptop run like that and perhaps when the computer runs you can fix these afterwards ?
            I have no clue how this works, but im doing my best.
            I also do not understand why the 2.11 version does not work, the dump i made looks not really corrupted..
            Anyone can explain something or help me in the right direction.. Thanks
            • fyzeler
              • Aug 2020
              • 26
              • Holland
              #26
              Anyone can fix the 2.03 bios that I earlier already posted with the 2.11 dump I made. Copy over the serial / keys and so on. Im clueless how to do so.
              Or any other fix..
              • peste
                • 13917
                • ROMANIA
                #27
                Or any other fix..
                try..bios extras site Acer
                DMI 33B000-33B0FF
                • fyzeler
                  • Aug 2020
                  • 26
                  • Holland
                  #28
                  Hi, thanks will try.. About the EC bios, I just leave it the way it is? The 2 mb ones I posted earlier is actually the EC bios (KBC?)
                  DMI 33B000-33B0FF
                  I have to copy over at 33B000? The file you posted does not contain any of my laptop info.. Please clarify, thanks.
                  • peste
                    • 13917
                    • ROMANIA
                    #29
                    yes ... you need to copy the information to your laptop..The DMI information is in that range ..
                    • fyzeler
                      • Aug 2020
                      • 26
                      • Holland
                      #30
                      Ok Then, And the windows key can copy too?
                      • lapfix
                        • Mar 2020
                        • 2764
                        • my workshop
                        #31
                        Yes : 303000-30303F
                        • fyzeler
                          • Aug 2020
                          • 26
                          • Holland
                          #32
                          Thanks, I'll solder over the chip this afternoon. Hope for the best. Will update..
                          Too bad btw the clip not work for this chip. Lot of work to desolder and solder again..
                          • lapfix
                            • Mar 2020
                            • 2764
                            • my workshop
                            #33
                            Using clip is a bad idea .
                            • fyzeler
                              • Aug 2020
                              • 26
                              • Holland
                              #34
                              The laptop can run again. Great. Thanks for the help for that.
                              Though I'm now having trouble with some things. When the laptop lid is closed and open again, the laptop gave blue screen and reboot. Other time it just stay black it went shut down and other time it just reboots and reboots again. Also sometimes the laptop not respond on the power button, after two times boot and it's off, no respond to the power button. I take out power supply, wait a bit and connect, then starts again??
                              Also the laptop does not respond to the fn+esc buttons, it doesn't go into recovery mode. The power should blink, it does not.
                              Seeing this wasn't before all this happened on the 2.03 bios I assume it's got to do with the bios, I really suspect the EC bios which likely controls this..
                              Should I flash down back to 2.03 via the normale .exe way (insydeflash.exe) and hope this also restores also my EC chip back to normal. I suspect the EC/KBC chip has some leftover conflicting stuff from the flash to 2.11 that went corrupt.
                              Or should I flash again the 2.11 version via the normale .exe way. Or I shouldn't do this at all and someone has other suggestion.
                              I rather not brick it again have to solder out the chip again, seeing the clip not work on the chip......
                              Thanks! Hope for some further help is much appreciated.
                              • fyzeler
                                • Aug 2020
                                • 26
                                • Holland
                                #35
                                Also I could flash just the 2MB EC chip with ch341a, but I have no fresh stock.bin for that. For the 2.11 version..
                                Anyone have it or can make it?
                                https://www.acer.com/ac/nl/NL/conten...oduct/4653?b=1
                                theres the bios 2.11 and 2.08.
                                I do not know where the EC 2 MB bios is..
                                Thanks.
                                • fyzeler
                                  • Aug 2020
                                  • 26
                                  • Holland
                                  #36
                                  Definitely Bios related. Started the laptop this morning only on battery, doesn't show signs of life. Remove battery and put back, and it works again.
                                  The problem I described earlier is mostly to do with the laptop going into sleep or hibernate mode, this will cause a shutdown or a reboot with a windows error.
                                  Hope someone point me in the right direction on how to fix this problem.
                                  • fyzeler
                                    • Aug 2020
                                    • 26
                                    • Holland
                                    #37
                                    I have downgraded the bios to 2.03, i've done this via the normal way.. execute insydeflash.exe..
                                    Laptop seems more stable but still has issues. I'm not sure the EC was also flashed.
                                    Is it possible to dump the EC bios without attaching a clip / desolder? Just via a software way?
                                    • fyzeler
                                      • Aug 2020
                                      • 26
                                      • Holland
                                      #38
                                      Could someone confirm this is an EC file, this was included in the 2.03 version download, it has the 4 mb 2.03 version rom and a .ME file which is 2MB.
                                      IS this an EC file for the EC winbios chip of 2 mb?
                                      Confirm please, and if so is there anything I need to copy anything out of the ec bios dump or no need.
                                      Can also compare with the 2MB bios I posted here in the beginning of the THread where i thought it was the MAIN bios..
                                      THANKS.
                                      • to5it0
                                        by to5it0
                                        10-24-2025, 01:35 AM
                                        Acer TravelMate TravelMate P2 TMP215-53-59TB Notebook P2 Specification for Upgrade or Repair
                                        This specification for the Acer TravelMate TravelMate P2 TMP215-53-59TB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TravelMate P2 TMP215-53-59TB boardview and TravelMate P2 TMP215-53-59TB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        09-07-2024, 05:20 AM
                                        Acer TravelMate TravelMate P6 TMP614-52 Netbook P6 Specification for Upgrade or Repair
                                        This specification for the Acer TravelMate TravelMate P6 TMP614-52 Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TravelMate P6 TMP614-52 boardview and TravelMate P6 TMP614-52 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        Acer TravelMate TravelMate Spin B3 TMB311RN-31-C7XH Notebook Spin B3 Specification for Upgrade or Repair
                                        This specification for the Acer TravelMate TravelMate Spin B3 TMB311RN-31-C7XH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TravelMate Spin B3 TMB311RN-31-C7XH boardview and TravelMate Spin B3 TMB311RN-31-C7XH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                        Acer TravelMate TravelMate B3 (TMB311-31-C11C) Notebook B3 Specification for Upgrade or Repair
                                        This specification for the Acer TravelMate TravelMate B3 (TMB311-31-C11C) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TravelMate B3 (TMB311-31-C11C) boardview and TravelMate B3 (TMB311-31-C11C) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
