HP Pavilion dv5-1160ev bios
  • olorin
    • Sep 2013
    • 82
    • Greece
    bios chip is MACRONIX MX25L800.The bin file is inside zip file....Please check If i Have correct BIOS.Motherboard is daqt6amb8f0 rev f 482870-001
    • 22285
    Re: HP Pavilion dv5-1160ev bios
    bios .
    • olorin
      • Sep 2013
      • 82
      • Greece
      thank you very much...I will try it.....
      • olorin
        • Sep 2013
        • 82
        • Greece
        Now the laptop don't turn on at all!!!!
        Is dead with new BIOS
        Please help me!!!!
          • 22285
          have you checked the CMOS battery voltage ? .What programmer are you using,and the software version,are you desoldering the bios chip or using a clip.What part number is the bios chip ?
          EDIT: i posted the wrong bios,sorry. I checked your pictures in your other thread,its bios version 3603 you need.
          • olorin
            • Sep 2013
            • 82
            • Greece
            nothing again....all dead!!!
            Battery is OK
            Programmer is Minipro TL866CS
            App software is 6.85
            I desolder the BIOS chip.
            Chip is MACRONIX 25l8005m2c
            • lapfix
              • Mar 2020
              • 2764
              • my workshop
              Battery is OK
              What's your serial number
              • olorin
                • Sep 2013
                • 82
                • Greece
                Originally posted by lapfix
                what's your serial number
                cnf8471r9v
                • olorin
                  • Sep 2013
                  • 82
                  • Greece
                  Any help?
                    • 22285
                    The bios at post #5 was extracted from the HP bios update, there is no better bios you can use.Your problem is somewhere else.
                    • obuslive
                      • Jun 2017
                      • 9
                      • España
                      Muchas gracias, funciono la del post 5
                      • Bloodhoundje
                        by Bloodhoundje
                        03-16-2024, 03:12 PM
                      • macabook
                        by macabook
                        🧩 Initial Issue
                        07-24-2025, 02:17 PM
                      • cr4zychriss
                        by cr4zychriss
                        • Rebrand: PC Specialist
                        11-14-2025, 04:04 PM
                      • sssssssssssssss
                        Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
                        by sssssssssssssss
                        I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
                        Symptoms:
                        • Laptop powers on but no display at all (completely black screen)
                        • Caps Lock blinks twice with a pause, then repeats continuously
                        • F12 LED stays on permanently
                        • No POST, no boot sequence, nothing on screen
                        Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
                        What I've tried:
                        • Hardware reset (battery removal, power
                        09-04-2025, 06:45 AM
                      • pirati
                        by pirati
                        10-27-2025, 04:20 PM
