Please nm-a181 lenovo z510 clean me
  • bilen
    • Aug 2014
    • 637
    • istanbul
    The image comes in 20 seconds. Please clean me my dump.
  • peste
    • 13451
    • ROMANIA
    Re: Please nm-a181 lenovo z510 clean me
    try...extras site LENOVO
    • Claudiomfa
      • Nov 2015
      • 455
      • Portugal
      Your laptop have two bios chip. One 2MB and 2nd 4MB.
      • bilen
        • Aug 2014
        • 637
        • istanbul
        Thank you. working.
        • twonk9098
          Lenovo Legion 5 high fan spin turns off after 34 seconds
          by twonk9098
          I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
          I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
          I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
          I have tried a few new bios but exactly...
          07-14-2024, 11:19 AM
        • liquidzorch
          Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
          by liquidzorch
          Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
          10-18-2024, 05:19 PM
        • acata
          Lenovo T470 Turn on and off in seconds while charge
          by acata
          Lenovo T470 turns on and off in seconds while charging. But it won't turn on without charging.
          The power supply generates 0.1A, turns on with the orange LED, the fan spins for 1 second, and off.
          It looks like the motherboard has some work previously on the CPU and another component. came to me also without cmos battery.
          I don't have boardview for further examination.
          Please kindly assist me to solve this problems..
          03-25-2025, 08:32 AM
        • lawrenceptrini
          Lenovo Ideapad 100-15ibd restarts every few seconds continuously.
          by lawrenceptrini
          Laptop turns on and restarts every 7 seconds or so.
          Power led and Webcam led turn on and goes off repeatedly.
          Pressing the power button does absolutely nothing.
          Same thing happens whether the bios battery is connected or not.
          I tried resetting the bios, press power button to drain power etc.,
          but no change same thing. I tried numerous ram modules but same result.
          Using a desktop power supply I can see the amps going to zero and rebuilding,
          same thing with multimeter. Doesn't matter if I plug in adapter or main battery,...
          12-27-2024, 10:20 PM
        • ktmmotocross
          Lenovo Legion 5 Pro 16ACH6H bad crystal?, but now wont program. connection lost after 5 seconds
          by ktmmotocross
          Hello.
          Have this Lenovo Legion 5 Pro 16ACH6H that came with no start, only powerbutton light. i reflash bios and ec. no change. i replace one of soc cpu crystals and laptop start to work. but when i assemble it, keyboard not work. so i reflash back bios but when i try to reflash ec i get write error and now i connect to it but always read/write error and connection lost after 5 seconds.
          IC is ITE8277E - 256 programmer is vertyanov. i try to change back that crystal but still the same
          NM-D562 rev3.0
          sn- PF31EESB
          any ...
          01-22-2024, 05:33 AM
