Asus FX505DD Rev: 2.0 BIOS
  • ReedZed
    • Dec 2022
    • 11
    • Беларусь
    #41
    Re: Asus FX505DD Rev: 2.0 BIOS
    Find a sticker on the motherboard to identify the right bios.
    Also write your SIO (EC) size.
    how to determine EC size?
    • ReedZed
      • Dec 2022
      • 11
      • Беларусь
      #42
      Here is a photo
      • hardware1
        • Sep 2021
        • 2946
        • N/A
        #43
        Originally posted by ReedZed
        Here is a photo
        Here's your new file, try it and let me know.
        Attach the writing on the EC chip.
        all donations are welcome,
        • ReedZed
          • Dec 2022
          • 11
          • Беларусь
          #44
          here's your new file, try it and let me know.
          Attach the writing on the ec chip.
          it8987e bxa
          • hardware1
            • Sep 2021
            • 2946
            • N/A
            #45
            Originally posted by reedzed
            it8987e bxa
            128kb EC.
            • ReedZed
              • Dec 2022
              • 11
              • Беларусь
              #46
              128kb EC.
              Tell me what to do with this file? how to flash?
              • ReedZed
                • Dec 2022
                • 11
                • Беларусь
                #47
                128kb EC.
                I'm wondering if it's possible to flash a bios dump so that the multicontroller pulls up the EC
                • hardware1
                  • Sep 2021
                  • 2946
                  • N/A
                  #48
                  It could happen, try first to program the main bios and see the symptoms.
                  About the EC you should use a prober Programmer, read that post.
                  https://www.badcaps.net/forum/showpo...40&postcount=2
                  • ReedZed
                    • Dec 2022
                    • 11
                    • Беларусь
                    #49
                    now I will install the flash and write off the symptoms
                    • ReedZed
                      • Dec 2022
                      • 11
                      • Беларусь
                      #50
                      collected, the keyboard is amber, waiting for signs of life
                      • ReedZed
                        • Dec 2022
                        • 11
                        • Беларусь
                        #51
                        I walked again on the legs with a soldering iron, the keyboard is red, the speaker makes a sound periodically, there is no picture, there is no charging indicator. But if I reboot from the button, it will go into the BIOS
                        The serial number is not set, usb does not work either. ssd and sata work with interrupts
                        • hardware1
                          • Sep 2021
                          • 2946
                          • N/A
                          #52
                          I don't understand you well, what was your main problem and what's your problem now?
                          It should be without a serial number because you didn't give me the original file, how can I add it!
                          • ReedZed
                            • Dec 2022
                            • 11
                            • Беларусь
                            #53
                            After flashing the BIOS in Windows, the usb2.0 port stopped working and the hard drives began to work with interruptions. Windows loaded, but the disk seemed to start working and stop, working again and stopping again. As far as I understand, the microcontroller takes data from the flash bios before initialization. After flashing your file into the BIOS, all these problems remained. After I soldered the flash BIOS into place, the laptop did not turn on the first time, after a forced reboot it enters uefi, sees all the devices, but the problems remain. I want to know if I understand everything correctly, is it possible to write data for the multicontroller to the BIOS file so that it starts working as it should? I think that the problem is in the multicontroller, since all the voltages on the board are in perfect order. And one more thing, before the breakdown, I updated the BIOS with an .exe file from the official site and installed the chipset driver. After the reboot, what happened was described above
                            • jimore
                              • Nov 2020
                              • 179
                              • mexico
                              #54
                              Originally posted by SMDFlea
                              Post your bios backup .
                              pls help me clean this bios
                              • lapfix
                                • Mar 2020
                                • 2757
                                • my workshop
                                #55
                                AMD don't need a clean ME !
                                Try this and give feedback
                                • azad188
                                  • Aug 2016
                                  • 23
                                  • kurdistan
                                  #56
                                  Originally posted by peste
                                  bios extracted from the Asus site update.
                                  thankyou
                                  • andreiv
                                    • Aug 2020
                                    • 8
                                    • santander
                                    #57
                                    Here I leave my contribution bios + ec
                                    • String2016
                                      • Nov 2015
                                      • 2238
                                      • philippines
                                      #58
                                      I need a working bios on this asus fx505dt board id FX505DD REV 2,0, original file orange light turns on keyboard lights then goes off.Already tried bios here in forum but no light. original have light, I have attached the original file and pic of the board.can someone fix this bios please
                                        • 21692
                                        You MUST:
                                        • Post under a related thread if it exists
                                        • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                                        • Gcs_rma
                                          Banned
                                          • Dec 2023
                                          • 108
                                          • N/A
                                          #60
                                          try bios
                                          • grimacelord
                                            by grimacelord
                                            07-10-2025, 02:52 PM
                                            ASUS TUF Gaming FX505DD-BQ121 Notebook Specification for Upgrade or Repair
                                            This specification for the ASUS TUF Gaming FX505DD-BQ121 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DD-BQ121 boardview and FX505DD-BQ121 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 02:24 PM
                                            ASUS TUF Gaming FX505DU-AL085 Notebook Specification for Upgrade or Repair
                                            This specification for the ASUS TUF Gaming FX505DU-AL085 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DU-AL085 boardview and FX505DU-AL085 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            ASUS TUF Gaming FX505DD-BQ063 Notebook Specification for Upgrade or Repair
                                            This specification for the ASUS TUF Gaming FX505DD-BQ063 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DD-BQ063 boardview and FX505DD-BQ063 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 12:00 PM
                                            ASUS TUF Gaming FX505DU-BQ150 Notebook Specification for Upgrade or Repair
                                            This specification for the ASUS TUF Gaming FX505DU-BQ150 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DU-BQ150 boardview and FX505DU-BQ150 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 12:18 PM
