Hp probook 640 g1
  • shiriffsm
    Banned
    • Aug 2019
    • 35
    • 87116973284
    Hp probook 640 g1
    can anyone help me i have Probook 640 G1 with bios chip problem (the original chip is not working), i changed the chip and i reprogramme the new chip but the problem is when i turn on the laptop it takes about 15-20 seconds to show the hp logo, is there any solution. thanks in advance
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: Hp probook 640 g1
    post the delayed bios here.
    • shiriffsm
      Banned
      • Aug 2019
      • 35
      • 87116973284
      the old bios chip is not working so i don't have the old dump
      • peste
        • Dec 2016
        • 13924
        • ROMANIA
        post the bios with a delay of 15-20 sec.
        • lapfix
          • Mar 2020
          • 2764
          • my workshop
          So post the one you got it now .
          • shiriffsm
            Banned
            • Aug 2019
            • 35
            • 87116973284
            this the current bios
            • peste
              • Dec 2016
              • 13924
              • ROMANIA
              try,
              • shiriffsm
                Banned
                • Aug 2019
                • 35
                • 87116973284
                try,
                thank you very much now it's working good but it keep showing up this twoo errors
                • peste
                  • Dec 2016
                  • 13924
                  • ROMANIA
                  DMI information must be written.
                  try this..
                  https://www.youtube.com/watch?v=9T57ktw8n3Y
                  • shiriffsm
                    Banned
                    • Aug 2019
                    • 35
                    • 87116973284
                    try this..
                    Thanks again, now it working great.
                    • plateau
                      • Mar 2018
                      • 3
                      • Brazil
                      try,
                      You are a lifesaver, bro!!!!
                      I have used this BIOS file and my board now is alive!!!
                      I could use the BCU program to tattoo my new board and everything is ok.
                      One more time, thank you so much.
                      Regards, from Brazil.
                      • jc_cuerdo
                        • Sep 2020
                        • 13
                        • Philippines
                        mates, what did you put in product name??
                        product name:
                        i got the SKU or Product ID <<--- im sure
                        i got the serial number <<--- im sure
                        i got CT number <<--- im sure
                        i put product name HP Probook 640 G1 <--- im not sure to this
                        after edit and save still PRODUCT INFORMATION NOT VALID
                        The following product information programmed into the system board is missing or invalid
                        SYSTEM BOARD (00A)
                        Product Family
                        ENTER - Continue Startup
                        • jc_cuerdo
                          • Sep 2020
                          • 13
                          • Philippines
                          mates its ok already i miss the Product Family which is HP Probook thanks for the bios file and the link for bios edit thank you sir
                          • Mrrbonti
                            • Apr 2020
                            • 29
                            • Ghana
                            please i need help with my hp 640 g1.
                            it powers off after every 30 minutes.i have flashed the bios but problem not solved
                              • 22286
                              Clean the ME firmware and it will be solved .
                              Here`s a guide,including links to all the tools and firmware you`ll need
                              https://www.badcaps.net/forum/showthread.php?t=88533
                              • acedogblast
                                by acedogblast
                                11-02-2024, 05:13 PM
                              • DynaxSC
                                ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                by DynaxSC
                                Hi
                                I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                08-04-2025, 12:20 PM
                                by SMDFlea
                                Bad...
                                09-02-2021, 04:40 PM
                                HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                09-07-2024, 07:12 AM
                                09-07-2024, 06:40 AM
