Asus fx505dt
  • antoniolangepas
    • Mar 2024
    • 3
    • Ukraina
    #41
    Originally posted by SMDFlea
    Post your bios backup,even if its corrupt. Do you have the FX505DT model number on the bardcode sticker like this -> https://www.badcaps.net/filedata/fetch?id=3179176
    here
    Click image for larger version  Name:	IMG_20240318_084352.jpg Views:	0 Size:	536.7 KB ID:	3237420
    • peste
      • Dec 2016
      • 12880
      • ROMANIA
      #42
      You have the bios at post #38
      • antoniolangepas
        • Mar 2024
        • 3
        • Ukraina
        #43
        The firmware did not give any result. There is also a black screen and a cyclic reboot. I will dig further, apparently the reason is not in the bios.
        • kunz
          • Jul 2019
          • 7
          • indonesia
          #44
          please help me my tuf fx505dt no display .capslok have light and i try to hdmi still same no signal
          this is my original bios
        • underbreak
          • Aug 2023
          • 12
          • France
          #45
          Hi everyone, i'm looking for a Bios for my Asus TUF FX505 (F505DT-AL218T).
          I buyed this one from 2nd hand with "broken display only", i bought the new display and the laptop still turn on (keyboard light up) but nothing else (no fan spin no boot).
          I searched for bios on this forum and found one, i flashed it (after i made a copy of my original one). Now the laptop light up, fan spin and stop every 3 sec for about 15 sec, then fan spin max speed and shut down, alway no display.
          Is anyone able to make me a fonctionnal bios please ? Thank you !
            SMDFlea commented
            Editing a comment
            Thread merged with existing topic.
        • volinakis
          • Jan 2021
          • 2741
          • N/A
          #46
          try. Next time WRITE serial number, not photo with it, as in RULES of this forum.
          • underbreak
            • Aug 2023
            • 12
            • France
            #47
            Thank you for your help sory for the SN missing :/
            I flashed your bios, the laptop's fans spin 3 time then shut down.
            And now everytime i press the power on, only the keyboard light up, no fan spin, nothing else.
            I think somthing is toasted. Ty for your help anyway
            • volinakis
              • Jan 2021
              • 2741
              • N/A
              #48
              check soldering.
              • G. Sling
                • Nov 2024
                • 3
                • US
                #49
                Hello, looking for some help or direction. erased the IC chip by mistake so I dont have an original dump. I am not sure what to replace from a blank bios to make this work again.
                Model: FX505DT-UB52
                S/N: L9NRCV00X86338B
                MoBo: 60NR02D0-MB1100​
                its a ryzen 5 processor with 1650 nvidia gpu.
                any help is appreciated, thank you.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11813
                  #50
                  Model: FX505DT-UB52
                  FX505DT
                  • G. Sling
                    • Nov 2024
                    • 3
                    • US
                    #51
                    Thanks, tried but no luck. Keyboard flashes once and then nothing when I press power. Board is not shorted, I do have 1.8, 3.3, 5, and 12 volts on the coils but gpu and cpu are ice cold and fans do not spin. will try and find the boardview for this model. thanks again.
                    • techfixarena
                      • Aug 2020
                      • Malaysia
                      #52
                      Hi my laptop model as below, i would appreciate if would provide the bios of this model
                      Model: FX505D-TAL409T
                      S/N: L5NRCV005203199
                      • peste
                        • Dec 2016
                        • 12880
                        • ROMANIA
                        #53
                        post the contents of the bios chip even if it is corrupted..
                        • Felipe_Serra_83
                          • Nov 2023
                          • 25
                          • Chile
                          #54
                          Hi, all. I'm looking for a BIOS for the model below. Can't provide you with the dump because the chip got damaged in the process of taking it out.
                          Why did I needed desoldering it? Because I couldn't read it with the clamps of my CH341. I guessed the board didn't allow it, but I'm not sure if this is the case with this board model.
                          Serial number: M1NRCV00J494045
                          Make: ASUS
                          Model: FX505DT-BQ100T
                          Motherboard model, Not sure if this is it: E89382
                          (I have the PN of the mobo, if this helps): 60NR02D0-MB1000
                          Thank you very much in advance.
                            SMDFlea commented
                            Editing a comment
                            Try the bios posted by Volinakis ,8 posts above yours.
                        • erikson25
                          • Jun 2023
                          • 4
                          • Philippines
                          #55
                          Asus FX505DT-AL368T
                          I need Bios for this laptop not turning on it only flashes keyboard when i press the power button.
                          Thank you in advance
                          Model: FX505D
                          SN: KBNRCV01X801468F
                          attached here is my bios backup
                            ASUS TUF Gaming FX505DT-HN766T Notebook Specification for Upgrade or Repair
                            This specification for the ASUS TUF Gaming FX505DT-HN766T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-HN766T boardview and FX505DT-HN766T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                            09-07-2024, 12:10 AM
                            ASUS TUF Gaming FX505DT-HN536T Notebook Specification for Upgrade or Repair
                            This specification for the ASUS TUF Gaming FX505DT-HN536T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-HN536T boardview and FX505DT-HN536T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                            09-06-2024, 10:50 PM
                            ASUS TUF Gaming FX505DT-HN630T Notebook Specification for Upgrade or Repair
                            This specification for the ASUS TUF Gaming FX505DT-HN630T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-HN630T boardview and FX505DT-HN630T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                            ASUS TUF Gaming FX505DT-HN450 Notebook Specification for Upgrade or Repair
                            This specification for the ASUS TUF Gaming FX505DT-HN450 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-HN450 boardview and FX505DT-HN450 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-06-2024, 10:00 PM
                            ASUS TUF Gaming FX505DT-BQ236 Notebook Specification for Upgrade or Repair
                            This specification for the ASUS TUF Gaming FX505DT-BQ236 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-BQ236 boardview and FX505DT-BQ236 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-06-2024, 09:10 PM
