Asus fx505dt
  • snar
    • Feb 2018
    • 74
    • philippines
    Re: Asus fx505dt
    Hi everyone can you help me clean this bios. after windows update the laptop has no display. i will attach the old bios. than you in advance.
    laptop model: asus fx505dt-hn657t
    • hoaca388
      Badcaps
      • Jan 2022
      • 11868
      Re: Asus fx505dt
      Seroal number ? Don't forget bacause these are forum rules.
      • snar
        • Feb 2018
        • 74
        • philippines
        Re: Asus fx505dt
        Sorry sir. this is the serial sn: LANRCV00395441D
        Thank you
        • hoaca388
          Badcaps
          • Jan 2022
          • 11868
          Re: Asus fx505dt
          sorry sir. This is the serial sn: Lanrcv00395441d
          thank you
          fx505dt
          • snar
            • Feb 2018
            • 74
            • philippines
            Re: Asus fx505dt
            sir sorry for my mistake i just found out that my board code is
            FX505DD MB REV 2.0 this is written on the motherboard
            and this serial number is at the back of my laptop
            LANRCV00395441D
            thank you
            • snar
              • Feb 2018
              • 74
              • philippines
              #26
              Re: Asus fx505dt
              thank you sir i will try this one sir
              • hoaca388
                Badcaps
                • Jan 2022
                • 11868
                #27
                Re: Asus fx505dt
                LANRCV00395441D
                thank you
                Serial LANRCV00395441D leads to model FX505DT
                • snar
                  • Feb 2018
                  • 74
                  • philippines
                  #28
                  Re: Asus fx505dt
                  sir i just tested the bios but still no display but when i press the capslock the led is ok. even the external hdmi still no display
                  • qayyum786
                    • Aug 2018
                    • 1933
                    • INDIA
                    #29
                    Re: Asus fx505dt
                    sir i just tested the bios but still no display but when i press the capslock the led is ok. Even the external hdmi still no display
                    try again
                    • snar
                      • Feb 2018
                      • 74
                      • philippines
                      #30
                      Re: Asus fx505dt
                      thank you sir i will try this 3 bios
                      • qayyum786
                        • Aug 2018
                        • 1933
                        • INDIA
                        #31
                        Re: Asus fx505dt
                        chkk 1 by 1
                        1> i make new virgin bios extracted from asus support
                        2> i inject your dmi s.no in new one
                        3> i try to fix your originale bios as well
                        try your luck and chk which one will work for you
                        your keyboard has display when you press on and off capslock
                        so try to clean ram and remove ssd/nvme/m.2 and than chk
                        if still same than chk lcd pin voltages for dim display
                        • snar
                          • Feb 2018
                          • 74
                          • philippines
                          #32
                          Re: Asus fx505dt
                          Sir i did try your 3 bios.
                          1> asus X505Dt ORIG BIOS_BUGS REMOVED: still no display and the capslock led is off external hdmi no display
                          2>ASUS TUF Gaming FX505DT NEW+DMI_4MATIC :still no display and the capslock led is functioning on and off external hdmi no display
                          3>FX505DT VIRGIN BIOS EXTRACTED :still no display but the capslock led is functioning on and off external hdmi no display
                          lcd pin has 19v and 3v
                          clean and swap new ram still no display
                          • Paulo11
                            • Jan 2024
                            • 13
                            • Slovensko
                            #33
                            Hi, can somebody look in my bios ? My laptop won´t post. Keyboard lights up, caps lock didn´t work. Every rail is good. I didn´t find anything wrong with board itself. I tried several version from this forum nothing works for me. With some versions processor rail is restarting every 4-5sec(inc. original), with some it stais on but didn´t post.
                            (sorry for my english).
                            Make: ASUS
                            Model: FX505DT-BQ143
                            S/N: L8NRCV002034321
                            MoBo: 60NR02D0-MB1100 (I think?)
                            • Vesko356
                              Vesko356 commented
                              Editing a comment
                              The serial number, make, full model number, motherboard model and revision must be written at your request as per the rules. Not as a picture, part of the file name and so on. Next time make sure to do it as it should to avoid unnecessary clarifications and wasting of time please.
                          • volinakis
                            • Jan 2021
                            • 2744
                            • N/A
                            #34
                            Make: ASUS
                            try this one
                            • Paulo11
                              • Jan 2024
                              • 13
                              • Slovensko
                              #35
                              Thank you, unfortunately didn´t work.
                              After another 3 hours working on that laptop, I start to think that CPU or GPU is toast...
                              • Paulo11
                                • Jan 2024
                                • 13
                                • Slovensko
                                #36
                                Laptop fixed more here: https://www.badcaps.net/forum/troubl...8-asus-fx505dt
                                • pckolev
                                  • 10
                                  • Bulgaria
                                  #37
                                  need help for ASUS FX505DT no display
                                  when you plug the charger will give you orange light on laptop but it doesnt turn on or fan spin.
                                  here my bios bin file
                                  Make: ASUS
                                  Model: FX505DT-HN540
                                  S/N: M2NRCV00B306088
                                  PCV-FX505DD REV 2.0
                                • peste
                                  • Dec 2016
                                  • 12925
                                  • ROMANIA
                                  #38
                                  Make: ASUS
                                  PCV-FX505DD REV 2.0
                                  Bios extracted from Asus website update for FX505DT
                                  • antoniolangepas
                                    • Mar 2024
                                    • 3
                                    • Ukraina
                                    #39
                                    A bios is needed. The laptop's backlight is on, the orange diode is on and the battery is charging. It's warming up, the fans are spinning. There is no image.
                                    Марка: ASUS
                                    Модель: FX505DT-AL087
                                    S / N: L3NRCV01721212B
                                    ​I'm sorry for my English language
                                      • 21124
                                      Марка: ASUS
                                      Post your bios backup,even if its corrupt. Do you have the FX505DT model number on the bardcode sticker like this -> https://www.badcaps.net/filedata/fetch?id=3179176
                                        ASUS TUF Gaming FX505DT-HN766T Notebook Specification for Upgrade or Repair
                                        This specification for the ASUS TUF Gaming FX505DT-HN766T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-HN766T boardview and FX505DT-HN766T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                        09-07-2024, 12:10 AM
                                        ASUS TUF Gaming FX505DT-HN536T Notebook Specification for Upgrade or Repair
                                        This specification for the ASUS TUF Gaming FX505DT-HN536T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-HN536T boardview and FX505DT-HN536T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                        09-06-2024, 10:50 PM
                                        ASUS TUF Gaming FX505DT-HN630T Notebook Specification for Upgrade or Repair
                                        This specification for the ASUS TUF Gaming FX505DT-HN630T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-HN630T boardview and FX505DT-HN630T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                        ASUS TUF Gaming FX505DT-HN450 Notebook Specification for Upgrade or Repair
                                        This specification for the ASUS TUF Gaming FX505DT-HN450 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-HN450 boardview and FX505DT-HN450 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-06-2024, 10:00 PM
                                        ASUS TUF Gaming FX505DT-BQ236 Notebook Specification for Upgrade or Repair
                                        This specification for the ASUS TUF Gaming FX505DT-BQ236 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-BQ236 boardview and FX505DT-BQ236 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-06-2024, 09:10 PM
