Bios for NP300E5C-S02GR
  • kainblock
    • Jun 2020
    • Greece
    Has anyone have bios for NP300E5C-S02GR or a working one of another model?
    • 22279
    Re: Bios for NP300E5C-S02GR
    Post your bios backup here .
    • kainblock
      • Jun 2020
      • Greece
      I don't have one. Chip is faulty and I can't read it at least with my chip reader. I am newbie sorry. I don't know if I can do anything else
        • 22279
        What model is your bios programmer and are you using a clip or desoldered it ?
        • kainblock
          • Jun 2020
          • Greece
          My programmer is a CH341A . Although what its actually happened. I can't distinguish any letter on Laptop board BIOS chip, auto mode doesn't detect chip and asking from samsung BIOS or chip model didn't help at all because they refuse to give me any detail just a store 200 km/h away and I have to cross sea to reach it. I found out that I can do my job with Winbond 25Q64FVSIG witch is recognised by programmer.
          Thank you in advance for your time.
          • DynaxSC
            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
            by DynaxSC
            Hi
            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
            08-04-2025, 12:20 PM
          • thxd43
            Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
            by thxd43
            Hello, first of all, excuse me, I am using the translator, English is not my native language.
            I have a Lenovo ideapad 330S - 14IKB laptop.
            The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
            02-23-2023, 08:37 PM
          • cr4zychriss
            by cr4zychriss
            • Rebrand: PC Specialist
            11-14-2025, 04:04 PM
          • hotcrossedbuns999
            M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
            by hotcrossedbuns999
            My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
            1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
            2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
            3. I could only locate two chips that look like bios chips. Could someone verify this
            01-03-2025, 12:32 PM
          • capoplays
            Help with BIOS update on Dell G15 5515 after chip replacement
            by capoplays
            Hey everyone,
            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
            When I check the BIOS using the F12 menu Flash...
            10-24-2025, 06:53 AM
