lenovo IdeaPad S145 bios needed
  • hoaca388
    Badcaps
    • Jan 2022
    • 12330
    #421
    Originally posted by dreamer_x_x
    İ don't know model number because it erased . Laptop's motherboard model is nm-c171 rev:1 . İ want to replace for dmi from old bios to working bios. May you help me
    aaaaa
    • dreamer_x_x
      Ottoman Empire
      • Nov 2016
      • 18
      • turkey
      #422
      Originally posted by hoaca388
      aaaaa
      Did you change DMi ? Thanks . İ will try
      • russelldregz
        • Jun 2018
        • 17
        • philippines
        #423
        Good day!
        Can someone help me.
        No Display problem.
        Lenovo S145-14API
        sn: PF13FBQD
        Thank you.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12330
          #424
          Originally posted by russelldregz
          Good day!
          No Display problem.
          Lenovo S145-14API
          sn: PF13FBQD
          Thank you.
          S145-14API Laptop (ideapad) - Type 81UV
          • sonerpc
            • Oct 2015
            • 34
            • turkey
            #425
            Hello forum. The power button for Lenovo S145-15ıwl is blinking white. I think it is a bios problem. I am uploading the bios on it here. Can you please edit it? Good work.Also, do I need to install the software for ite8536 here? Or is just editing the main bios sufficient?
            MODEL:LENOVO İDEAPAD S145-15IWL / fv440/fs441/fs540 nm-c121 rev:1.0
            SN:PF13EJC7 MTM:81MV0010TX
            • peste
              • 13599
              • ROMANIA
              #426
              you have everything you need at post#45..
              • major44
                technical lab
                • Jun 2014
                • 5
                • ITA
                #427
                Hi guys!
                I have a Lenovo S145 under repair with the problem of the LED flashing at startup with a black screen,
                Is it possible to know if the bios that I extracted from the eeprom is damaged or is it working?
                the technical data are as follows.
                Ideapads: S145-15API
                Model: 81UT
                S/N: PF14XV6Y
                MTM: 81UT0034IX
                MO: PF9XB9911013
                Attached is the original extracted bios.​
                  Vesko356 commented
                  Editing a comment
                  Thread merged.
                  Please use the forum search to find related threads where you can post your request. You're NOT allowed to start a new thread if there's an existing one!!!
              • peste
                • 13599
                • ROMANIA
                #428
                Originally posted by major44
                Hi guys!
                Model: 81UT
                S/N: PF14XV6Y
                MTM: 81UT0034IX
                MO: PF9XB9911013
                You have everything you need at post #29
                • major44
                  technical lab
                  • Jun 2014
                  • 5
                  • ITA
                  #429
                  Thank you for your answer!
                  I flashed the bios released in post 29 but the problem changed, at the first startup the LED remained lit with the black screen then after 5-6 seconds it went off, at the next startup it was the same, 5-6 seconds then it went off, at on the third restart the LED remains lit but the screen is black, the fan starts turning normally again as soon as the CPU warms up.​
                  • anything
                    • Apr 2019
                    • 28
                    • kurdistan
                    #430
                    fs440fs541 nm-c111 rev 1.0
                    No display, no led light. i want to try dump bios
                    p/n : 5B20S42282
                    s/n : pf259he8
                    model : lenovo ideapad s145 15igm
                      SMDFlea commented
                      Editing a comment
                      Your backup is only 25.0KB compressed,it is corrupt or a bad backup. Make another backup
                  • major44
                    technical lab
                    • Jun 2014
                    • 5
                    • ITA
                    #431
                    UPDATES: I fixed the problem, discovered some low quality silver conductive thermal grease under the CPU cooler causing shorts between the filtering SMD capacitors, did a deep clean and flashed the bios previously recommended by PESTE post #29 and that's it worked fine worked again, later formatted with windows and returned. Thank you very much for the availability of the forum technicians!
                    • vanjo1991
                      • Sep 2019
                      • 5
                      • philippines
                      #432
                      please use this orig bios bin not the ived sent already
                      please help
                    • sosit
                      • Feb 2023
                      • 43
                      • oman
                      #433
                      anyone fix this bios
                      Lenovo s145
                      FV440/FS441/FS540 NM-C121 REV:1.0
                      Power light and fan spin few seconds and restarting
                      battery charging is fine
                      original bios attached
                      please anyone fix
                      Thanks Advance
                    • sosit
                      • Feb 2023
                      • 43
                      • oman
                      #434
                      Lenovo s145 -14iwl
                      S/N:PF1DU0VA
                      please anyone fix
                      Thanks Advance​
                      • B_Viktar
                        • Apr 2024
                        Hello together,
                        I have a problem with Lenovo IdeaPad S145-15IWL, Model: 81MV
                        After trying to update the BIOS, the notebook is dead. I got 1Hz blinked power LED. Read a lot of topics on the forum and probe to repair the BIOS image myself. I cannot find the DMI sector in my old image, and by getting the new BIOS image from .exe file I have failed.
                        Could someone help me to repair the old BIOS image?
                        Model name: 81MW
                        S/N: PF2214Q9
                        MTM: 81MW019
                        Motherboard: FV440/FS441/FS540 NM-C121 Rev 1.0
                        Original BIOS attached.
                        Thanks in advance.
                        • peste
                          • 13599
                          • ROMANIA
                          #436
                          Originally posted by B_Viktar
                          Hello together,
                          Model name: 81MW
                          S/N: PF2214Q9
                          MTM: 81MW019
                          Thanks in advance.
                          you have everything you need at post #46
                          • peste
                            • 13599
                            • ROMANIA
                            #437
                            Lenovo s145 -14iwl
                            S/N:PF1DU0VA
                            please anyone fix
                            Thanks Advance​
                            try post #4
                            https://www.badcaps.net/forum/troubl...wl#post1754058
                            • Arshad alam4659
                              • Aug 2020
                              • 157
                              • India
                              #438
                              Hi guys!
                              I NEED BIOS​
                              lenovo ideapad s145-15IWL D NM-C121 REV 1.0 I5 8TH GEN
                              • peste
                                • 13599
                                • ROMANIA
                                #439
                                Originally posted by Arshad alam4659
                                Hi guys!
                                I NEED BIOS​
                                read...https://www.badcaps.net/forum/troubl...before-posting
                                • Arshad alam4659
                                  • Aug 2020
                                  • 157
                                  • India
                                  #440
                                  Hi guys!
                                  I NEED BIOS
                                  lenovo ideapad s145-15IWL D NM-C121 REV 1.0 I5 8TH GEN​
                                • joven016
                                  Lenovo Ideapad S145 need working bios HELP!!
                                  by joven016
                                  Problem is blinking power led only
                                  i don't know exactly if it's s145-15igm or s145-14igm
                                  have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                  Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                  Already tested some of posted bios here
                                  S145-14igm - success but invalid serial and not booting on OS
                                  S145-15igm - success with serial and some other info in bios but still not booting on OS
                                  already tried installing new windows but always booting on bios setup
                                  windows installer flash drive detected on...
                                  08-21-2025, 10:55 PM
                                • mximiliandz
                                  help bios lenovo ideapad s145-14iil type 81w6
                                  by mximiliandz
                                  Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                  06-20-2025, 06:50 AM
                                • mkdj
                                  Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                  by mkdj
                                  Dear all,
                                  I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                  Here the steps I have taken to fix the laptop:
                                  - downloaded latest BIOS from Lenovo Website...
                                  10-18-2025, 03:43 AM
                                  Lenovo IdeaPad S145 Notebook S Specification for Upgrade or Repair
                                  This specification for the Lenovo IdeaPad S145 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S145 boardview and S145 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad S145...
                                  09-06-2024, 04:40 PM
                                  09-06-2024, 04:00 PM
