lenovo IdeaPad S145 bios needed
Re: lenovo IdeaPad S145 bios needed
S145-15IWL Laptop (ideapad) - Type 81MVOriginally posted by Subhasish91S/n pf146rwb↵
https://www.badcaps.net/donateComment
Hello, can someone please help me in this case. I bought replacement board for s145-15iwl but seller from Aliexpress sent me s145-14iwl board.
Laptop works, but not numeric pad and delete key. (Insert behaves as Delete).
I understand why, because 14" model has compact keyboard with power button placed on "delete" key location.
Since both models are covered by same BIOS on Lenovo website, I wonder how is differed which one is 14" and which one is 15" model? Is there some fixed part of BIOS where that is set in factory, or that can be hacked/tricked to work? Or you need to enter Product or MTM (because now is empty)
I read about some BIOS advanced menu, but I found no way to access such menu on this board.
Any help is appreciated, especially from people who have experience with this.Comment
I don't think the bios is the problem... I think you have to change the keyboard too... if the boards are similar, from the socket on the motherboard and the I/O chip... (routes)....Hello, can someone please help me in this case. I bought replacement board for s145-15iwl but seller from Aliexpress sent me s145-14iwl board.
Any help is appreciated, especially from people who have experience with this.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Did you manage to install it without the DMI?
Hello, what does DMI mean?
have bios in bin format of lenovo ideapad s145-15API (motherboard: GS440&GS540 NMC511 REV-1)Comment
The serial number,windows key.
If you`ve made a good backup you`ll find everything you need to make a new bios with your DMI at post 342
.Last edited by SMDFlea; 11-25-2023, 11:26 AM.Comment
lenovo IdeaPad S145-15IWL bios needed
I need an updated Bios. Power LED is blinking. Attached the read out Bios.
Bios/EC Version: ASCN39WW
MTM: 81MV014QGE
Serial number: PF214HF1
Thanks a lotAttached FilesComment
Re: lenovo IdeaPad S145-15IWL bios needed
you`ll find everything you need to make a new bios with your DMI at post 342Last edited by SMDFlea; 11-25-2023, 11:25 AM.Comment
Already tasted. Continues to blink. Video was there before. Laptop is but always regularly rebooted so every 10 seconds. Battery charges normally without interruption. Could call Bios but after the 10 seconds always reboot the laptop. So no Biosupdate possible via Windows. Therefore tried to flash. Chip can be written normally and also read out again. But comes when writing verifity error at 00000022 or 00000042. Already tried different Bioschips when writing. Therefore, I thought I'm doing something wrong with the Bios bin creation.
Translated with www.********/Translator (free version)Comment
Hello.
Lenovo S145-15API 81UT, gs440&gs540 nmc511 rev 1.0
The laptop's LED was flashing and it wouldn't boot. I uploaded the bios from the Internet and the laptop started up. Unfortunately, I can't cope with copying DMI to the new bios. Can anyone find the DMI in the old bios?
EDIT
sn PF1XDE5KAttached FilesLast edited by Dominiks1980; 11-25-2023, 10:12 AM.Comment
You must post the laptop serial number - https://www.badcaps.net/forum/troubl...before-postingHello.
Is the bios you attached the original one,the DMI is corrupt.Find another S145-15API bios in this thread to use with someone elses DMI in it (and the windows key),the laptop will work.If you want to change it try the U1 tool and Thinkpad config info utility - https://www.badcaps.net/forum/troubl...ls#post1622424Comment
I added the serial number to the post
The bios that I attached to the post is a bios downloaded from a laptop, I don't know if it is original. Searching for the serial number in the hex editor does not find it. Could this not be the original bios?Comment
The DMI is encrypted so you can`t see the serial in the bios.The Offsets are 1000 - 2FFF ,starts with the word LENV. Sorry i didn`t look at it more carefully earlier,it looked like it was empty but there is some code there.If you want to copy the DMI yourself you`ll find everything you need at post 342Last edited by SMDFlea; 11-25-2023, 10:33 AM.Comment
In post 326:
"The DMI and Key is at these offsets DMI 520000 - 5207FF , Key 62D000 - 62D03F"
Only it's not in my bios 5207FF and 62D03FComment
The bios I added to the post does not work. This is the bios that was in the laptop. I searched the Internet and downloaded the BIOS which works. Now I want to experience DMI from the Bios that I added to the post, to the BIOS from the Internet that works.Comment
by joven016Problem is blinking power led only
i don't know exactly if it's s145-15igm or s145-14igm
have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
Already tested some of posted bios here
S145-14igm - success but invalid serial and not booting on OS
S145-15igm - success with serial and some other info in bios but still not booting on OS
already tried installing new windows but always booting on bios setup
windows installer flash drive detected on...-
Channel: BIOS Requests ONLY!
by mximiliandzGood morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
by mkdjDear all,
I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
Here the steps I have taken to fix the laptop:
- downloaded latest BIOS from Lenovo Website... -
This specification for the Lenovo IdeaPad S145 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S145 boardview and S145 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad S145...09-06-2024, 04:40 PM
This specification for the Lenovo IdeaPad S145 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S145 boardview and S145 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad S145...09-06-2024, 04:00 PM
- Loading...
