Macbook Air 2014 - A1465 EMC 2631
  • dotmhd
    • Apr 2020
    • 6
    • France
    Can you guys help me cleaning the EFI password on this backup ? I finally got my first programmer and I'd like to try it on my old motherboards.
    This one is a Macbook Air early 2014, EMC 2631.
    Serial number : C02N1NPYG083
    Thank you in advance for your help
  • peste
    • 13915
    • ROMANIA
    Re: Macbook Air 2014 - A1465 EMC 2631
    try...
    • Claudiomfa
      • Nov 2015
      • 455
      • Portugal
      Try and report
      • dotmhd
        • Apr 2020
        • 6
        • France
        Originally posted by peste
        try...
        Thank you very well ! It worked like a charm using AsProgrammer
        • dotmhd
          • Apr 2020
          • 6
          • France
          Hello guys, sorry to bother you again. On this motherboard, I was able to boot from an external drive to start either MacOS installer or MacOS running on live, but when the install is over I get a message asking for a 4-digits PIN. Is it possible to remove that using my programmer too ?
          Thank you !
          • bachir2004
            • Feb 2015
            • 439
            • maroc
            Thank you !
            just PRAM RESET 2 or 3 times before install.
            • bachir2004
              • Feb 2015
              • 439
              • maroc
              https://www.badcaps.net/forum/showthread.php?t=83639
              • dotmhd
                • Apr 2020
                • 6
                • France
                Thank you for the answer, do you know how I can do that on this specitif model ? When I hold "P+R+Alt+CMD" just after pressing power, the Macbook boots as usual, it doesn't reboot after a seconds like on the older Macbooks... Is that normal ?
                • bachir2004
                  • Feb 2015
                  • 439
                  • maroc
                  No it is not.try an external keyboard.
                  https://support.apple.com/fr-ma/HT204063
                  • dotmhd
                    • Apr 2020
                    • 6
                    • France
                    I was finally able again to reset PRAM. It's my fault, I've set my EFI password again after cleaning it with the programmer, and obviously, the Mac doesn't allo users to reset PRAM if a password is set !
                    I'll install MacOS now, thank you very much for your help !
                      Apple MacBook Pro 13'' Early 2014 820-2530 820-2530-A 820-2530-B Boardview
                      Apple MacBook Pro 13'' Early 2014 820-2530 820-2530-A 820-2530-B Boardview...
                      10-22-2024, 03:26 AM
                    • peste
                      MacBook Air model A1465, EMC 2631
                      by peste
                      hello..MacBook Air model A1465, EMC 2631, motherboard 820-3435-B, liquid flow in it ... after washing the motherboard, without anything connected (keyboard, hdd, wifi board, etc),
                      connect the charger and the laptop start like in the video, and so on, the voltages seem ok ... does anyone have any idea?...
                      11-15-2021, 10:28 AM
                    • ritalo
                      MacBook Air 13 2014 - Remove EFI password
                      by ritalo
                      I have a MacBook Air 13 inches 2014.
                      I have set a EFI password and I can't remember it : now I want to reinstall macOS and I can't because the MacBook is asking for the password.
                      I know how to remove the password with a usb programmer.
                      I plug the usb programmer to the motherboard and to my pc with usb, I read the EFI and I save it to a file.
                      Then I have to find this value in the file : $SVS because it indicate where is the password.
                      But I can't find the value.
                      I have attached the file​
                      Thank...
                      05-14-2024, 12:10 PM
                    • envym
                      by envym
                      Hi everyone!
                      06-27-2025, 08:54 AM
                    • itsmeapple
                      MacBook Pro Charges When Off, But Not When On (MBP 2014 15 Inch) 820-3662-A
                      by itsmeapple
                      I'm facing an issue with my MacBook Pro.
                      When it's switched off, it charges while the battery is connected. However, when it's powered on, the charging stops after a few seconds.
                      Another strange thing is that when I disconnect the battery and plug in the charger, the MacBook Pro turns on and runs without any issues.
                      I've already tried using a different OEM charger, but no luck. I even swapped the charging port DC-IN, but the problem persists.
                      Has anyone else experienced this issue before?
                      Thank you!...
                      02-21-2025, 02:22 PM
