BIOS dump RroBook 4740s
  • mr.Data
    • Sep 2018
    • 74
    • Netherlands
    Need bios dump for ProBook 4740s with Radeon graphics
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: BIOS dump RroBook 4740s
    Post your backup bios
    • mr.Data
      • Sep 2018
      • 74
      • Netherlands
      Unfortunately backup didnt go well. Seems to be largely an empty dump
      • Claudiomfa
        • Nov 2015
        • 455
        • Portugal
        try and report
        This file is a dump from other laptop.
        • mr.Data
          • Sep 2018
          • 74
          • Netherlands
          Thanks for sharing.
          Programming the chip without any errors but the charging light keeps blinking. Unable to boot the laptop.
          • String2016
            • Nov 2015
            • 2238
            • philippines
            try with another original hp charger
            • mr.Data
              • Sep 2018
              • 74
              • Netherlands
              Same result.
              Can it be a faulty chip?
              • Claudiomfa
                • Nov 2015
                • 455
                • Portugal
                Try this ME Cleared file
                • mr.Data
                  • Sep 2018
                  • 74
                  • Netherlands
                  Working, thank you very much!
                  Is it possible to change product name to ProBook 4740s or is it not worth the effort?
                  • Claudiomfa
                    • Nov 2015
                    • 455
                    • Portugal
                    Yes. you need nbdmifit or hp BCU software to change dmi information.
                    • mr.Data
                      • Sep 2018
                      • 74
                      • Netherlands
                      Is it possible that the Radeon GPU isn't recognized anymore because of the BIOS?
                        • 20898
                        Yes. Try this bios .
                        • mr.Data
                          • Sep 2018
                          • 74
                          • Netherlands
                          Unfortunately it does not work. Power light blinking again.
                          • usedcom1
                            • May 2021
                            • 4
                            • Polska
                            Bios HP 4740s Intel + AMD ok!!
                            • salawayon
                              • Nov 2012
                              • 568
                              • philippines
                              Thank you for the file.. it's working..
                              • egelaptop
                                • Jun 2015
                                • 123
                                • türkiye
                                thank you
                                • Habble7
                                  by Habble7
                                  Suspected Cause:
                                  Troubleshooting Attempts:
                                  05-22-2025, 07:28 AM
                                • studdy05
                                  Bricked HP Probook 450 G7 Bios questions
                                  by studdy05
                                  Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                  Ive got...
                                  07-08-2025, 09:24 PM
                                • Citymin
                                  by Citymin
                                  S/N : 5RNK9FFT70...
                                  08-05-2025, 05:12 AM
                                • DynaxSC
                                  by DynaxSC
                                  11-17-2023, 10:56 AM
                                  HP ProBook 4740s 4000 Specification for Upgrade or Repair
                                  This specification for the HP ProBook 4740s can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 4740s boardview and 4740s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ProBook 4740s is accurate,...
                                  09-06-2024, 05:27 AM
