mec 16xx dump with info block
    Re: mec 16xx dump with info block
    Originally posted by coolshrimp View Post
    Ok now that that is solved ill share my diagram and instructions.
    T14s - MEC-1663 - Jtag - Pinout - Bios Password Removal
    Now next issue setting Serial / Model / Etc.
    Lenovo T14s (NM-B891)
    Iv Tried to Use Lenovo Maintenance Utility 1.89 (i7tm38us)
    But I get and error *EEPROM Overflow
    Same issue here: https://www.badcaps.net/forum/showth...EPROM+overflow
    You are using MEC-1633#ISP in RT809H Settings, the resulting file is 192k, is this the correct size? shouldn't it be 256 or 290?
      Using MEC-1633#ISP Worked for me and others recommended but there is a MEC-16xx 256k option that could be selected instead.
        I work on a T14 G1, I tested your settings, and also with 256K, I got a 256K file with more data then the 192k at the end of the file
          I looked at my file and you’re right there is more info at the end that was cut off.
          On mine the cut off was just blank padding no content so likely why it had no effect.
          So the 256k would be a better option.
          Depending what MEC chip your Reading the size may be different.
            I looked at my file and you're right there is more info at the end that was cut off.
            it's a MEC-1663 , after read-erase-wait 2 mn without power-write-put back resistor , still password there. (192k file), not tested to write 256k yet
              to my knowledge, choosing either 192k or 256k is fine, same result
              and so if you did the "read erase remove all power sources including cmos batt" and the password is still there, then it is probably not a bios password you are dealing with, just remove the SSD it should work fine it's a hard disk password
                Using RT809F, choosing MEC1633-256K , unlock done.
                Don't choose MEC1633#ISP , it provide 192K file and password is not removed after write back.
                  has someone figuered out how to unlock the AMD version as well?
                    that it! after weeks of trying to unlock my x13 gen 1 laptop with my svod4 i finally manage to unlock it with an rt809h it was easy thank for all your infos on this website it help, but i did it with the rt809h not with the svod4
                      Hello, This board is for the Lenovo X1 Yoga gen 5, I need to read the MEC1663 chip but I am asking if the indicated red button is the JTAG pins outs ?
                      Also I knocked out one resistor and i believe it is 10K 0201 resistor.
                      thank you in advance.
                        Yes, somebody connected like the attachment photo.
                          Thank you for your reply, I have the same cable with RT809H, I will try it out and let the forum know.
                            How did you make jtag for t490 mec 1663
                              Originally posted by ahmed14net View Post
                              how did you make jtag for t490 mec 1663
                              like this ... without RST
                                Please can you help me label which one it is TMS, RST, TDI, TDO and GND. Thank you
                                  like this :
                                    like this :
                                    Yes I saw the flying configuarions from previows post and or on the RT809H but this is different. On your image looks like the jtag pin number 5 is GND but on the x1 Yoga Gen 5 pin number 6 is GND
                                      Hello!
                                      Anyone can help me?
                                      Lenovo: ThinkPad T14 Gen 1
                                      MB: NM-C931 with MEC1663
                                      Issue: Need to remove BIOS PASSWORD
                                      SVOD4
                                      I moved R8715 to R8716 position and solder the wires to the JTAG Port, I am getting this from the SVOD: (see image)
                                      And when clicking read, it reads the MEC but I cannot see any data on the HEX section. (The machine does power up)
                                      I am afraid to clic on erase and brick the computer!
                                      Any help?
                                      Thanks!
                                        MEC1663 has 290 kb not 192kb probably your svod4 cannot flash normal this chip,or settings not normal read manual
                                        Kill the state in yourself and you will be free like a wind...
                                          Thanks four your answer
                                          I am able to "Confic MEC" with 288K but same result, when reading nothing appears on the HEX.
                                          How can I read manual?
