ES1-432 BIOS need to fix
  • String2016
    • Nov 2015
    • 2242
    • philippines
    I need help on this acer ES1-432 laptop, turns on fan is not spinning no display, already tried flashed the bios that i got here in this forum but still the same issue.I attached the original main and 1mb file can someone please fix this
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: ES1-432 BIOS need to fix
    Very likely Its not a bios issue. Check VS voltage lines first eg +3V VS
    • mkdj
      What should I do after having flashed a BIOS?
      by mkdj
      Dear all,
      I did my first laptop repair related to a BIOS issue. Laptop is a Lenovo ThinkPad T480, and was not booting. With my brand new programmer, I did a back-up of the current not working BIOS, erased the BIOS chip, and flashed this dump: https://www.badcaps.net/forum/troubl...83#post3686683
      Now the laptop works fine, I can access BIOS and boot on a USB drive. But I read stuff about DMI, and...
      09-09-2025, 09:45 AM
    • Loli Popu
      DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
      by Loli Popu
      Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
      12-13-2024, 03:28 AM
    • drux
      Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
      by drux
      I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
      Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
      These models have AMI/Aptio BIOS.
      Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
      11-03-2024, 01:18 AM
    • istvanszasz99
      Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
      by istvanszasz99
      Product ID: RZ09-0421
      Motherboard: CH580
      Bios File Size: 32,768 KB
      Dear Forum Readers!
      !!! MY RAZER BLADE...
      11-24-2025, 05:52 PM
    • zenius
      by zenius
      12-08-2024, 06:13 AM
