Hp elitebook 840 g5 bios password
    Originally posted by hoaca388 View Post
    VVV
    hoaca388 Thank You but it still asks for the password on your file.
    Vesko356 I don't think there's an option to edit the post, so I'm adding the info here
    HP EliteBook 840 G5
    CTNumber 6GPRH05TZBF809
    Product 2FA66AV
    Serial 5CG8509CWB
    Build Id 17WWCSBT602#SABD#DABD
      HP EliteBook 840 G5
      Product 2FA66AV
      Serial 5CG8509CWB
      Again
      Become a Badcaps supporter
      Thanks to all supporters.
        Thank you very much hoaca388 , with this file the laptop starts in "manufactured" mode (I guess that's how it should be?), after filling in the missing data in the BIOS, everything works as it should. I would like to know how to unlock the 32MB bios myself, but it's probably a secret? Thank you again for your help and best regards
          HP Elitebook 840 G5
          Serial Number : 5CG9183NQT
          Password Remove please
          Attaching Backup Bios
            Originally posted by gctdpacov View Post
            HP Elitebook 840 G5
            this file is not the main bios. find the other chip 32mb and upload here.
              attaching other chip
                only flash this ec. use RC unlocker in all HP 16MB ec next time.
                  Hi, i blown resistor next to 16mb bios chip. Does someone knows what value is it?
                    If it is attach with pin 6 than its a SPI_CLK resistor
                    you can take a reverence of any schematic which has 25Q128JVPQ
                    (you can check pin 5 resistor value and place same ohm on missing resistor )
                      Resistor is between pins 7 and 8
                        you may try with 10K or 3.3K
                          The fan spins once, the charging light flashes. can you fix the bios?
                          HP EliteBook 840 G6
                          serial : 5CG9443TMY
                            HP EliteBook 840 G6
                            serial : 5CG9443TMY
                            you posted in wrong thread this thread is for 840 G5 only.
                              Removing BIOS Password please
                              HP Elitebook 840 G5
                              S/N : 5CG936B9WW
                              Attaching BIOS dump of MX25L256 Chip
                              Thank you...
                                HP Elitebook 840 G5
                                S/N : 5CG936B9WW
                                Thank you...
                                post EC backup
                                  post EC backup
                                  I found this chip on the backside of the board on U366 : ISSI IC25LP128
                                  I guess this is the EC , right?
                                  I have to unsolder the chip with my hot air station and will post the dump.
                                    Vesko356 commented
                                    Editing a comment
                                    Yes, U366 - ISSI IC25LP128 is indeed the EC memory chip.
                                  HP Elitebook 840 G5
                                  S/N : 5CG936B9WW
                                  Thank you...
                                  i don't know why i cant upload directly a file so i attached this link instead.
                                  no need EC file.
                                  first boot press f10 apply factory setting to defaults and exit, and 2nd boot reset security settings to defaults.
                                  here's your DMI info use BCU:
                                  Serial Number: 5CG936B9WW
                                  Product Number: 2FA64AV
                                  CT Number: PGWHQ00WBCQ2YU
                                  Description: HP EliteBook 840 G5
                                  build_id: 17WWCSCT601#SABD#DABD
                                  Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAfXhKhkjh.Rq
                                  MAC Address: 04-0E-3C-CC-6D-C6
                                  MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
                                    no need EC file.
                                    Thank you very much!
                                    Your patched bios file worked perfect without touching the EC chip.
                                      RCUnlocker can delete computrace lock? Sorry, this is my first time encountering this. The laptop was blocked for organization; the laptop was scrapped. I was able to fix it, it did not turn on, but I see a blockage when installing windows.
                                      computro 6050a2945601-mb-a01(1a)
                                      HP Elitebook 840 G5
                                        RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
                                        You MUST:
                                        • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
