need clean ME region DA0ZQFMB6F0 REV:F
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi iaheve a problem with this unit it will just display acer then after that black screen.
    HARDRIVE IS OK
    LCD DISPLAY OK
    I will try to flash the bios with clean me region.
    Big thanks if someone will help me
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: need clean ME region DA0ZQFMB6F0 REV:F
    No harm in trying but not likely to be me-region issue.
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      did you experience with this type of models sir? or even heardabout this issue?
      • rein2017
        • Jun 2017
        • 35
        • Philippines
        replace the high side mosfet near CPU it will work 100% ive done this many times this the label ( 6414A) hope it helps
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          THANKS SIR .. ive solve the problem using youre suggestion
          • superdota2
            • Jun 2015
            • 64
            • PHILPPINES
            thank you, this one solve my board issue
            • bertoy
              • Mar 2021
              • philippines
              hi guys a have same model acer aspire es1-432.Ram and cpu dont have voltage.and i cant fine the controler in motherboard.schematics show me the controler for 1.35 volts is in PU5 RT8231B and i cant finf this ic.please help
              • tom3k
                Dell Precision 5540. Need clean ME Region
                by tom3k
                Laptop: Dell Precision 5540
                MB: LA-H331P Rev: 1.0(A00)
                Hi.
                I am looking for a clean ME Region 12.0.95.2489 Corporate H CNP/CMP-H B, A
                After extracting my BIOS in FIT the ME Region size is 7565 KB.
                However the ME Region files I fouud online are 11688 KB in size.
                Can someone help me find he correct clean ME Region?
                Thanks!
                Code:
                ║ Family │ CSE ME ║
                06-28-2025, 12:34 PM
              • Adenitz
                Clean ME region - a bit of theory
                by Adenitz
                Hello laptop repair experts,
                can someone plese, help me understand the significance of cleaning ME region in a BIOS dump file?
                I know that Manegement Engine (ME) data is part of BIOS/UEFI firmware. I know that it contains some HW specific data for the particular laptop.
                What I don't know, why do I need to clean ME region if I try BIOS dump file from another laptop (of course same type and model). I'm not sure if this is only because of the serial number (not sure if that is stored in ME region at all).
                Recently, I had a two cases where laptops (one is Lenovo Idepad...
                10-21-2023, 04:44 AM
              • Lexsmash85
                Bricked bios from a legion y540-15irh (81sx) . Needing dmi/clean me region maybe
                by Lexsmash85
                Edit: apologies, I only need help with the DMI info.. I thought the ME region would need attention in order to recover from bricked state but maybe I misunderstood.
                Im a novice to this experience but in short, I performed a backlash from the latest and final bios firmware BHCN45WW to BHCN26WW hoping that would solve an issue with keyboard functionality failing after an update. Ended up hanging during flash process and then system would no longer POST on reboot.
                USB recovery process didn't seem to take. So today I successfully managed to get the BIOS dump from my machine...
                08-06-2025, 03:41 AM
              • konovalec85
                Clear me region Acer VERITON L670G Q45T-AS
                by konovalec85
                Hello
                Can someone help clean the ME region?
                I flashed the BIOS with this file and writes intel me unconfiguration in progress when loading
                I wanted to try to clean the region myself, but I don't know which and where to get a file with a clean region for this motherboard. And what version do I need?
                FITool 10.0.46.1002?
                Chipset * North Bridge – Intel Q45 * South Bridge – Intel ICH10...
                01-12-2025, 05:14 AM
              • eenee
                bios txe region y116te_e_glk
                by eenee
                It's possibly a Chinese offbrand laptop that uses a generic series of motherboards called y116te. It has no image.All power rails are working. No bios dumps could be found on the internet. Tried similar bios from this thread. No difference. I wanna try cleaning the TXE region of the bios but cleaning TXE region seems too advanced for my skills. Please help clean the TXE region from this dump ...
                05-15-2024, 02:39 AM
