e540 NM-A161
  • bilen
    • Aug 2014
    • 638
    • istanbul
    e540 NM-A161
    Old dump : late image and 30 min power off
    Can you fix this ?
  • peste
    • Dec 2016
    • 12786
    • ROMANIA
    Re: e540 NM-A161
    try...
    • bilen
      • Aug 2014
      • 638
      • istanbul
      Re: e540 NM-A161
      Originally posted by peste
      try...
      file 12582 kb ?? There is a problem
      • peste
        • Dec 2016
        • 12786
        • ROMANIA
        Re: e540 NM-A161
        sorry...try this...
        • bilen
          • Aug 2014
          • 638
          • istanbul
          Re: e540 NM-A161
          sorry...try this...
          shutdown problem continues
            • 20873
            Re: e540 NM-A161
            The ME firmware can`t be fixed properly (the manual way using the guide at win-raid) because you only posted one bios backup. The E540 has a dual bios, 8MB and 4MB.To clean the ME firmware you have to merge/stitch both bios together using a hex editor first,and only then can the ME be cleaned with FITC.
            Post your 4MB bios here or find a bios on the forum using the Search .
            https://winraid.level1techs.com/t/gu...lization/31277
              • 20873
              Re: e540 NM-A161
              sorry...try this...
              @peste ,how are you cleaning the ME firmware,are you using the manual way with fitc or using some software,such as easy me clean ??
              • bilen
                • Aug 2014
                • 638
                • istanbul
                Re: e540 NM-A161
                here :
                • bachir2004
                  • Feb 2015
                  • 437
                  • maroc
                  Re: e540 NM-A161
                  the manual does not work for above third generation,but with fit,the results are always sure,from what i have been able to test.
                  • bachir2004
                    • Feb 2015
                    • 437
                    • maroc
                    Re: e540 NM-A161
                    try this one.
                    • peste
                      • Dec 2016
                      • 12786
                      • ROMANIA
                      Re: e540 NM-A161
                      The program "easy me clean" use it less ,and only for older laptops, for new model laptops the method does not work very well. I usually use the fitc method.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Re: e540 NM-A161
                        Can you tell us the PCH number on your mb And which processor you are using to test the mb? Just check processor compatibility as some pch like SJTNV supports only celeron and dual core processor.
                        • godit3
                          chrisTech
                          • Nov 2015
                          • 29
                          • ghana
                          Re: e540 NM-A161
                          here :
                          @bilen
                          please were you able to find the clear ME file for your laptop?
                          • godit3
                            chrisTech
                            • Nov 2015
                            • 29
                            • ghana
                            Re: e540 NM-A161
                            here is the clear ME
                            • nsilvan
                              • Mar 2019
                              • 30
                              • baja california
                              Re: e540 NM-A161
                              GODIT3 THIS BIOS IS WORKING THANKS MANB
                              • eghbalm
                                • Nov 2016
                                • 8
                                • iran
                                Re: e540 NM-A161
                                tank you
                                • jogas
                                  • Oct 2019
                                  • 17
                                  • IE
                                  Re: e540 NM-A161
                                  hi need help for password remove from bios.try patcher didnt worked.thanks
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11732
                                    Re: e540 NM-A161
                                    Because your file corrupted. Backup fault.
                                    • jogas
                                      • Oct 2019
                                      • 17
                                      • IE
                                      Re: e540 NM-A161
                                      hi.hm but laptop boot.but with code.read using svod3.any chance to get ump wihout password.i try few dumps from here but they locked too
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11732
                                        Re: e540 NM-A161
                                        You didn't understand what I meant. Your bios reading failed, it outputs a corrupt file.
                                        • f-bone
                                          Asus K513E no image, bios dump attached
                                          by f-bone
                                          Hi guys!
                                          I have this laptop which is turning on but has no image. I have attached the bios dump but I can't seem to find a working one. I also read a similar thread mentioning WBT.exe v314 but no instructions on how to use that.
                                          Can you please help me with a working binary that includes the DMI info from my dump? Or kick me to the right direction to try and add the DMI section myself? I used HxD on my dump and found the serial on multiple places so I am not sure what to copy.
                                          thank you very much in advance!
                                          br,
                                          george...
                                          07-04-2023, 02:27 AM
                                        • DynaxSC
                                          by DynaxSC
                                          06-14-2024, 03:49 PM
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                          HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-06-2024, 10:56 AM
                                          HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
