need bios Asus p2520l p552la
  • alirafee
    • Jun 2015
    • 80
    • iran
    hi
    i need bios p2520l
    p552la
  • cacla
    • Apr 2015
    • 442
    Re: need bios Asus p2520l p552la
    try this one
    • jokophp
      • Dec 2017
      • 39
      • indonesia
      master, you have EC file?
      • tembeki
        • Mar 2019
        • Türkiye
        Asus P2520L main board P552LA
        hi please asus p552la_lj rev 2.1 bios need
        • peste
          • Dec 2016
          • 12806
          • ROMANIA
          Re: Asus P2520L main board P552LA
          post the bios backup here
          • erolakay
            • Jan 2020
            • 9
            • türkiye
            hi
            i need bios p2528l
            p552la
            • didouche1200
              • Oct 2016
              • 358
              • 82679911441
              asus p552la_lj rev 2.0 ec bios
              i need ec bios for ite 8585e asus p552la
              thanks
              • peste
                • Dec 2016
                • 12806
                • ROMANIA
                Re: asus p552la_lj rev 2.0 ec bios
                thanks
                post pictures with white or green stickers in the ram memory area
                • formaldeide
                  • Nov 2022
                  • 4
                  • Italy
                  I'm trying to repair my old Asus laptop P2520LA-XO0281D, motherboard version is P552LA-LJ Rev2.1. The issue seems to be well know, that is black screen on startup with continuos reset due to corrupted BIOS image.
                  The FLASH NOR IC is an Winbond W25Q64FVSS.
                  So, someone have a full updated BIOS image to load on it?
                    • 20898
                    Make a backup and try the one at post #2 ,if that doesn`t work then post your laptop serial number and bios backup
                    • formaldeide
                      • Nov 2022
                      • 4
                      • Italy
                      Thanks! Cacla's image seems to work pretty well. Maybe the two motherboard versions are identical for the BIOS?
                      I had to restart it once before the POST appear, S/N is missing from BIOS configurator system page but shouldn't it be a problem, right?
                      SN: G1NXCV18K37503A
                      • hardware1
                        • Sep 2021
                        • 2930
                        • N/A
                        SN: G1NXCV18K37503A
                        Try this file and let me know the results.
                        all donations are welcome,
                        • formaldeide
                          • Nov 2022
                          • 4
                          • Italy
                          Thank you, it works pretty well!
                          • cellphoneyeta
                            ShortedboardGSM
                            • Oct 2015
                            • 49
                            • philippines
                            pls clean mine too sir...
                            SN: F6NXWU00902623F
                            THANKS
                            • hardware1
                              • Sep 2021
                              • 2930
                              • N/A
                              SN: F6NXWU00902623F
                              THANKS
                              Here's your New BIOS, try it.
                              • cellphoneyeta
                                ShortedboardGSM
                                • Oct 2015
                                • 49
                                • philippines
                                thanks..i will try and post result later
                                • beal
                                  • Jul 2017
                                  • 97
                                  • Iran
                                  Test ok
                                  Very Thanks
                                  • hardware1
                                    • Sep 2021
                                    • 2930
                                    • N/A
                                    Originally posted by beal
                                    Test ok
                                    Very Thanks
                                    You're welcome.
                                    • recep1982
                                      • Aug 2014
                                      • 90
                                      • istanbul
                                      dude it doesn't see hdd and ssd can you fix the bios? please help me.
                                      • Vesko356
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        Read the rules before posting!
                                        You MUST:
                                        • Read BIOS guides, methods, resources and tools
                                        • Try the method at BIOS guides, methods, resources and tools before requesting help
                                        • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                        • Use search function in case someone already answered your request
                                        • Post under a related thread if it exists
                                        • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
                                        • Name your thread with model numbers and request
                                        • Provide a BIOS/EC dump if possible
                                        • Attach files directly to your post instead of linking to external websites
                                        • Post what the problem is, be specific - black screen, no boot, running slow, password.
                                          Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
                                        Become a Badcaps supporter
                                        Thanks to all supporters.​
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • lrouw84
                                          by lrouw84
                                          Hi there,
                                          01-28-2023, 01:31 PM
