I have this bios with power on and no display please need one correct the problem thanks.
a1466 820-3209-a
Tags: None
by ValtekkenSpecs:
- CPU=AMD Ryzen 5 3500U
- GPU=(integrated) Radeon Vega Mobile
- RAM=8GB (2x4GB, a 4GB set is soldered), DDR4; 1x4GB Ramaxel, 2400MT/s, RMSA3310MJ86H9F-3200; 1x4GB Micron, 2400 MT/s, no part number (soldered)
- Storage=512GB, NVMe SSD, hfm512gdhtni-87a0b
My issue isn't massive, but I'd like to get this solved since I'm trying to fix a friend's laptop.
A botched BIOS update by Lenovo bricked this laptop, so I used my BIOS programmer to reflash the BIOS on it and saved it from an early demise. All is good now, but the BIOS reports the S/N, MTM and UUID... -
by objecttothisI had a desktop form factor mini-server die on me a few weeks ago. Through my initial diagnostics, I was convinced it was the motherboard because when I shorted the Green wire on the ATX connecter, the multimeter gave me all the correct voltages on the various pins of the ATX connector and 5VSTB was also correct. To my surprise the replacement motherboard wouldn't turn on with the case power button either. I threw in another PSU and it turned on right away. This is an 80 Plus EVGA 430W PSU with PN:100-W1-0430. I pulled the cover off and don't see any immediately obvious blown caps or scorch...
by psdavid65I received a 2013 Macbook Air A1466 A1466 820-3437-B motherboard WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?
Channel: BIOS Requests ONLY!
by dimis1975I have a macboook air a1466 that stopped charging the battery.
BAT PINS: with or without ADAPTER IN
1- GND
2- GND
3- GND
4-0V sense pin
5-3.42V
6-3.42V
7- 8.4V
8- 8.4V
9- 8.4V
AC Adapter plugged in: after a lot of of hours some times start charging
No BAT Connected- Green to Orange
AC Adapter plugged in: BAT Connected- no light
The strange thing, when I tried a mac charger usb-c with usb-c to macsafe 2 adapter works normally and charging.
Any ideas what’s wrong please?...08-05-2025, 03:43 AM -
by Sergio KubCould someone help me?
I have a Macbook Air A1466 EMC 3178 - 2017, board 820-00165 and sometimes the boot interrupts with an image of a folder and a question mark.
Could it be the BIOS? - Loading...
