HP Probook 645 G1 bios
  • khelane
    • Apr 2015
    • 168
    • xxxx
    hi all
    i need a bios HP Probook 645 G1
    6050a2567101-mb-a02
    i tested 6050a2567101-mb-a03 can't entre bios
    tnx
  • khelane
    • Apr 2015
    • 168
    • xxxx
    Re: HP Probook 645 G1 bios
    i found it
    tested and laptop work
    • mainah njoroge
      • Aug 2017
      • 36
      • kenya
      thank you
      • Layth
        • 29
        • iraq
        thanx
        • Zillions Tech
          • Jul 2022
          • 26
          • Nigeria
          • dqtech
            Badcaps
            • Jul 2018
            • 630
            • N/A
            thanks
            • Jabirma
              • Sep 2022
              • 13
              • Nigeria
              Tnx
              • khubaib76
                M Asim
                • Nov 2021
                • pakistan
                thank you
                • hadyshahat
                  EGYPT
                  • May 2023
                  • 35
                  • Egypt
                  thank you
                  • jodans
                    • Jun 2021
                    • 26
                    • Philippines
                    thank you
                    • rogfanther
                      • Jul 2006
                      • 458
                      • Brazil
                      I´ve got this HP Probook 645 G1 with corrupt bios.
                      The original bios, and one that worked ( obtained here on Badcaps, thanks folks ! ) are attached.
                      The stickers in the machine are worn, so I do not know all the data. Could somebody explai how to extract ( if possible ) the missing DMI data from the original bios, or maybe how to enter the missing information ?
                      On boot, the notebook states
                      "Manufacturing Program Mode Set 6 of 10".
                      Missing
                      System Board (00A)
                      Product Name
                      Serial Number
                      SKU
                      Family
                      System Board CT Number
                      It has motherboard 6050A2567101-MB-A03.
                      In the lone sticker in the machine, I have
                      Serial Number BRJ533WKYT
                      Product H7L95EC#AC4 <- Woud this be the SKU ?
                      On the motherboard, I´ve got
                      Serial Number YC4CBR05ED
                      CT PEBHH00WB7T0DT
                      MAC D0BF9C210C84
                      Which serial should I use? The one of the machine, or that on the motherboard ?
                      Is it enough to boot to MSDOS, run BCU to edit those variables, then run it again to Lock ?
                      Also, I do not know the Feature Byte ( and maybe some other things ). Are they necessary ?
                      Thanks !!​
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11743
                        DMI added.
                        • rogfanther
                          • Jul 2006
                          • 458
                          • Brazil
                          Originally posted by hoaca388
                          DMI added.
                          thanks ! Will try later. !
                          • wino25
                            • Nov 2022
                            • 4
                            • Nigeria
                            Thanks you 👍
                            • MERIT PC DOCTOR
                              • Nov 2024
                              • Tanzania
                              [QUOTE=khelane;n1383924]Re: HP Probook 645 G1 bios
                              thanks
                              i will try it
                              • mohamed12
                                • Aug 2023
                                • egypt
                                i try the last one it,s good but the bios inter need to password ... what is the password
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11743
                                  https://www.badcaps.net/forum/troubl...349-rcunlocker
                                  • clawwer
                                    • Mar 2021
                                    • 10
                                    • philippines
                                    i found it
                                    thank you..work!
                                    • studdy05
                                      Bricked HP Probook 450 G7 Bios questions
                                      by studdy05
                                      Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                      Ive got...
                                      07-08-2025, 09:24 PM
                                    • macabook
                                      by macabook
                                      🧩 Initial Issue
                                      07-24-2025, 02:17 PM
                                    • Vesko356
                                      by Vesko356
                                      08-11-2023, 03:27 AM
                                    • the_raz
                                      Need (unlocked) bios for HP Probook 450 G3 Notebook
                                      by the_raz
                                      I'm requesting a bios .bin for 2 of my hp Probook 450 G3's. Both of which I had forgotten the bios passwords. I stupidly flashed both of them with firmware "made" by the RCUnlocker software and I guess I shouldn't have. The last thing I did was flash both of them with RCUnlocker-fw thinking it would 100% work and left my programmer etc behind and won't have access to them for another 2 days so I figured I'd create a thread to see if I'd be so lucky that someone might have a working file laying around 😝
                                      Laptop number 1:
                                      Model: HP ProBook 450 G3
                                      Motherboard part number:...
                                      12-17-2024, 03:37 PM
                                    • jbonavita
                                      by jbonavita
                                      Some issues
                                      Things I tried
                                      04-29-2025, 09:38 PM
