Need Bios for X456UV MAIN BOARD REV:2.0
  • arjel
    • Nov 2019
    • 8
    • Philippines
    Hi everyone....
    Thanks..
  • mahmoodjavan
    Banned
    • Mar 2018
    • 584
    • iran
    Re: Need Bios for X456UV MAIN BOARD REV:2.0
    Originally posted by arjel
    Hi everyone....
    Thanks..
    test plz
    • arjel
      • Nov 2019
      • 8
      • Philippines
      not working...but thanks a lot for your effort..
        • 22275
        Post your original bios backup .
        • neamum
          • Feb 2015
          • 8
          Need bios for asus x409ub rev 2.0
          • qayyum786
            • Aug 2018
            • 1959
            • INDIA
            try
            • neamum
              • Feb 2015
              • 8
              Thank you!
              It is too big, the original has 8,192 KB.
              • qayyum786
                • Aug 2018
                • 1959
                • INDIA
                thank you!
                It is too big, the original has 8,192 kb.
                post your backup dump
                • neamum
                  • Feb 2015
                  • 8
                  Old Bios for asus x409ub rev 2.0
                  • qayyum786
                    • Aug 2018
                    • 1959
                    • INDIA
                    try
                    • neamum
                      • Feb 2015
                      • 8
                      It doesn't work, nothing starts with it
                      • nubie2112
                        • Oct 2020
                        • indonesia
                        original
                        • DynaxSC
                          by DynaxSC
                          11-17-2023, 10:56 AM
                        • Dani_2024
                          by Dani_2024
                          10-28-2024, 05:06 PM
                        • ygorsan
                          by ygorsan
                          🧩 Problem Summary:
                          • I
                          07-28-2025, 08:34 AM
                        • jb_Bak
                          by jb_Bak
                          CN6401
                          Pin 01 NC
                          Pin 02 NC
                          Pin 03 "BL_ON": 0V
                          Pin 04 "N/C"
                          Pin 05 "STBY 3.3V": 3.5V
                          Pin 06 "GND": N/C
                          Pin 07 "AC_OFF"...
                          09-27-2021, 04:52 PM
                        • JDC
                          by JDC
                          ONN 100012588
                          Long answer:
                          07-15-2022, 07:39 AM
