UX550GD BIOS dump
  • hoootony
    • Nov 2019
    • Taiwan
    UX550GD BIOS dump
    Need help about UX550GD BIOS dump
    • 22275
    Re: UX550GD BIOS dump
    Post your bios backup here .
    • hoootony
      • Nov 2019
      • Taiwan
      Sorry, my bios is broken. so I need replace it.
        • 22275
        How is it broken,can`t you read anything from it at all, even a corrupt bios dump.
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • haitham sharabati
          by haitham sharabati
          Hello engineers 😀,
          🔧 Device Info:
          - Model: HP 15-da2007ne
          - Product Number: 8XF55EA#ABV
          - Serial Number: CND0338P0D
          - CPU: Intel Celeron N4000
          💀 Problem:😅
          08-07-2025, 04:54 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • DynaxSC
          by DynaxSC
          11-17-2023, 10:56 AM
