Re: Lenovo ThinkPad T470s BIOS
hello i want to repair my bios nm-b081 rev 1.0 t470s
Hi need bios t470s type;20jt-s10s00 sn pc-omgb47 thanks in advanceLeave a comment:
Here you go., this is an 100% Original - Non-patched BIOS Bin file for Lenovo Thinkpad 470s. It might be having a PW but works 100%...Attached Filesif you find these attachements useful please consider making a small donation to the site
This only I told you that copy a Non-Patched one.. I will check later whether I have one Non-patched in my database, will surely help you, np...Leave a comment:
I used a patched one and it displayed hardware id and I pressed enter and space bar a couple times and shut it off.
Can i flash it with any non patched bios now and it should work?Leave a comment:
Try anyone of the zip attachments, all should work as they are in original form & only asked for P/W removal or not booting up fast... One Should work.Leave a comment:
[QUOTE=husnu16;1176331]Read this carefully : https://www.badcaps.net/forum/showthread.php?t=87588Attached Filesif you find these attachements useful please consider making a small donation to the site
[QUOTE=hoaca388;1151370]hi master, please clear password my bios bin file.
T470s
type 20js-0021ge
sn: pc-0tb3x7Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi Guys,
thx a lot, all is working now. The issue was on my side ... my soldering skills
, accidentally desolder the diode close to BIOS chip, which provides the power to BIOS chip ... thx again, very much appreciate your help
Hi Thx a lot, but it is not working ... I flash the bios, but when I plug the PSU, the power button light up for a moment and stays dead ... not possible to power up. From time to time the cooling fan turns on for a moment and then turns off. All BIOS files do the same behavior. I have used the NeoProgrammer with Ch341a and XGecu TL866II plus ... same result. Am I doing something wrong? Hopefully, I haven't destroyed the motherboard
Or should I desolder the bios chip for programming?Last edited by dopson; 10-05-2022, 08:21 AM.Leave a comment:
T470s (type 20HF, 20HG) Laptop (ThinkPad) - Type 20HGAttached Filesif you find these attachements useful please consider making a small donation to the site
Try this 16mb file. there is nothing to do with your 1mb EC.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi Guys, can anybody help me to bring my t470s back to life?
It is the model 20HG. I made a backup of BIOS (attached).
The serial number is PC-0S6VCF.
Very much appreciate any help.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Lenovo T470s Bios
I don't think you misread the bios file, maybe writing the bios file to the chip is faulty if you use the CH341A with a clamp. Or you can try cleaning the ME area of the original file.Leave a comment:
Lenovo T470s Bios
Hi, I'm trying to update my laptop bios with a password and I don't care about data on disk.
Laptop: Lenovo T470s
Type 20JT-S0VY00
Bios: 25Q128JVSQ
Programmer: CH341APro
Software: NeoProgrammer and AsProgrammer
1. I read twice with incorrect chip configuration the Bios
2. I compared them and were equals
3. I patched with lenovo_autopatcher
4. Write patched bios
but I suppose that as I readed wrong on step 1, it will not work anymore.
After that, I look on internet for a lot of different bios versions and write them without luck.
What I'm doing wrong?
How could I recover this laptop?
Thanks in advanceAttached Filesif you find these attachements useful please consider making a small donation to the site
[QUOTE=hoaca388;1151370]Hello Sir,
The Device working well i re-flash and detect that there is small IC beside the BIOS chip removed by mistakes
after new BIOS you send it working well, i can restart and shutdown the turn on without problem
Thank You Soooooooooooo muchLeave a comment:
[QUOTE=hoaca388;1151370]Thank you for replaying, i try this file but notworking at all the all keyboard led flickering on time then, on the original file the device working well but there is problem when i make shutdown or restart i could not turn on until i press power up to 20 second the the device working wellLeave a comment:
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
This specification for the Lenovo ThinkPad T470s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T470s boardview and T470s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-06-2024, 11:30 AM
This specification for the Lenovo ThinkPad T470s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T470s boardview and T470s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-06-2024, 11:29 AM
This specification for the Lenovo ThinkPad T470s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T470s boardview and T470s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-06-2024, 09:00 AM
- Loading...
