Lenovo ThinkPad T470s BIOS
  • mehdiab17
    replied
    Re: Lenovo ThinkPad T470s BIOS
    hello i want to repair my bios nm-b081 rev 1.0 t470s
  • dahnking
    replied
    Originally posted by mferna14
    Here you go., this is an 100% Original - Non-patched BIOS Bin file for Lenovo Thinkpad 470s. It might be having a PW but works 100%...
    Thank you working
  • hoaca388
    replied
    Originally posted by kimolimo
    Hi need bios t470s type;20jt-s10s00 sn pc-omgb47 thanks in advance
    Post your corrupted bios file and remember to write the correct serial number ( 0_ zero , O_ orange )
  • kimolimo
    replied
  • mferna14
    replied
  • mferna14
    replied
    This only I told you that copy a Non-Patched one.. I will check later whether I have one Non-patched in my database, will surely help you, np...
  • trili
    replied
    Try anyone of the zip attachments, all should work as they are in original form & only asked for P/W removal or not booting up fast... One Should work.
    I used a patched one and it displayed hardware id and I pressed enter and space bar a couple times and shut it off.
    Can i flash it with any non patched bios now and it should work?
  • mferna14
    replied
  • hoaca388
    replied
    [QUOTE=husnu16;1176331]
    Originally posted by hoaca388
    hi master, please clear password my bios bin file.
    T470s
    type 20js-0021ge
    sn: pc-0tb3x7
    Read this carefully : https://www.badcaps.net/forum/showthread.php?t=87588
  • husnu16
    replied
    [QUOTE=hoaca388;1151370]
    Originally posted by huss584
    T470s (type 20HF, 20HG) Laptop (ThinkPad) - Type 20HG
    Serial number : PC0RYF1J
    T470s
    type 20js-0021ge
    sn: pc-0tb3x7
  • dopson
    replied
    Originally posted by dopson
    Thx a lot, same result as with the previous file
    Hi Guys,
    thx a lot, all is working now. The issue was on my side ... my soldering skills , accidentally desolder the diode close to BIOS chip, which provides the power to BIOS chip ... thx again, very much appreciate your help
  • dopson
    replied
  • dopson
    replied
    Try this 16mb file. there is nothing to do with your 1mb EC.
    Hi Thx a lot, but it is not working ... I flash the bios, but when I plug the PSU, the power button light up for a moment and stays dead ... not possible to power up. From time to time the cooling fan turns on for a moment and then turns off. All BIOS files do the same behavior. I have used the NeoProgrammer with Ch341a and XGecu TL866II plus ... same result. Am I doing something wrong? Hopefully, I haven't destroyed the motherboard
    Or should I desolder the bios chip for programming?
  • hoaca388
    replied
    Hi Guys, can anybody help me to bring my t470s back to life?
    It is the model 20HG. I made a backup of BIOS (attached).
    The serial number is PC-0S6VCF.
    Very much appreciate any help.
  • hardware1
    replied
  • dopson
    replied
  • hoaca388
    replied
    Re: Lenovo T470s Bios
    I don't think you misread the bios file, maybe writing the bios file to the chip is faulty if you use the CH341A with a clamp. Or you can try cleaning the ME area of the original file.
    Last edited by piernov; 08-28-2022, 05:39 AM. Reason: remove full quote of previous post
  • Siuto
    replied
    Lenovo T470s Bios
    Hi, I'm trying to update my laptop bios with a password and I don't care about data on disk.
    Laptop: Lenovo T470s
    Type 20JT-S0VY00
    Bios: 25Q128JVSQ
    Programmer: CH341APro
    Software: NeoProgrammer and AsProgrammer
    1. I read twice with incorrect chip configuration the Bios
    2. I compared them and were equals
    3. I patched with lenovo_autopatcher
    4. Write patched bios
    but I suppose that as I readed wrong on step 1, it will not work anymore.
    After that, I look on internet for a lot of different bios versions and write them without luck.
    What I'm doing wrong?
    How could I recover this laptop?
    Thanks in advance
  • huss584
    replied
    Hello Sir,
    The Device working well i re-flash and detect that there is small IC beside the BIOS chip removed by mistakes
    after new BIOS you send it working well, i can restart and shutdown the turn on without problem
    Thank You Soooooooooooo much
  • huss584
    replied
    Thank you for replaying, i try this file but notworking at all the all keyboard led flickering on time then, on the original file the device working well but there is problem when i make shutdown or restart i could not turn on until i press power up to 20 second the the device working well
  • lucaszmn
    by lucaszmn
    Problem:
    Initial Findings:
    • I concluded that the
    08-12-2025, 03:01 PM
  • to5it0
    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
    by to5it0
    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
    I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
    This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
    I have opened the laptop and identified the main BIOS chip...
    10-24-2025, 01:35 AM
    Lenovo ThinkPad T470s Notebook T Specification for Upgrade or Repair
    This specification for the Lenovo ThinkPad T470s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T470s boardview and T470s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
    09-06-2024, 11:30 AM
    09-06-2024, 11:29 AM
    09-06-2024, 09:00 AM
