Razer Blade RZ09_0301 BIOS Dump
  • r.carlo
    • Nov 2019
    • 4
    Hello, does anyone have a RZ09_0301 BIOS .bin file? I've been stuck without a laptop for a while due to a corrupt BIOS. Now that I've found a way to flash it with the CH341a flash programmer, I'm hoping someone can provide the dump.
    Thank you!
    • 21692
    Re: Razer Blade RZ09_0301 BIOS Dump
    That part number is for the wifi card on the FCC label. The model number should have 5 digits after RZ09-
    See this thread : https://www.badcaps.net/forum/showthread.php?t=76992 Post your model number if yours isn`t listed in that thread.
    • r.carlo
      • Nov 2019
      • 4
      Thanks SMDFlea!
      • vinaypundith
        Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
        by vinaypundith
        I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
        So, I'm looking for a BIOS dump for this machine - a 16MB one....
        08-03-2024, 12:32 PM
      • spmetroil
        Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
        by spmetroil
        I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
        The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
        I have a CH341A programmer and I already attempted the following steps:
        1. Identified the correct chip (W25Q128, 3.3V SPI flash).
        2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
        3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
        08-19-2025, 09:23 AM
      • haitham sharabati
        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
        by haitham sharabati
        Hello engineers 😀,
        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
        🔧 Device Info:
        - Model: HP 15-da2007ne
        - Product Number: 8XF55EA#ABV
        - Serial Number: CND0338P0D
        - CPU: Intel Celeron N4000
        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
        💀 Problem:😅
        - Device shows “Administrator Password”...
        08-07-2025, 04:54 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • bestrafer
        Lenovo L460 LAN issue after BIOS dump flash
        by bestrafer
        Hello everyone.
        I have L460 Type 20FV (2 X 8MB bios chips) with no boot issue after BIOS update (black screen with restarts, common issue on this model + BIOS update).
        BIOS dump(s) from this post https://www.badcaps.net/forum/showpo...7&postcount=27 makes the laptop boot absolutely fine, no delays, etc..
        But there is an exclamation mark in the device manager for the LAN card right after fresh OS installation - LAN naturally doesn't work. I saw requests like "BIOS: fix LAN" on other sites.
        Could someone point on a direction...
        01-31-2023, 01:14 PM
