Acer Aspire E5-575 Bios
  • REpairAT
    • Nov 2020
    • 142
    • Austria
    #61
    Re: Acer Aspire E5-575 Bios
    Originally posted by volinakis
    try clean ME version
    tried to clean it by myself and also flashed this one now, sadly no success...
    • volinakis
      • Jan 2021
      • 2733
      • N/A
      #62
      try this one
      • khoirudin29
        • Nov 2023
        • indonesia
        #63
        good morning, let me introduce myself, my name is khoirudin, I experienced the same thing with my laptop, namely the LED indicator is on, but the cooling fan is off & the screen is dark when turned on, does anyone have the bios file (.bin) for the Acer aspire, type E5-575-32ND? model number: N16Q2, I found the post I was looking for (this forum), only the type is a little different, I have tried flashing it with the file that has been shared on this forum, but it doesn't match, the laptop indicator LED is actually dead. I think with the right type, my laptop can return to normal, thank you.
        • peste
          • Dec 2016
          • 12811
          • ROMANIA
          #64
          post the original bios of the laptop, the S/N..
          • ludo28
            • Aug 2022
            • 37
            • france
            #65
            Hello
            Build Bios Please My old bios
            Problem Black Screen
            e5-575g DAZAAMB16E0 REV: E zaa x32 (ZAAA)
          • dexter_kevin
            • Sep 2017
            • 23
            • Sri Lanka
            #66
            Try this file ME cleared.. and EC file for kbc
            Thanks alot. this worked 100% with i5 7th gen with nvidia graphics
            • angerian
              • Sep 2021
              • philippines
              #67
              try this bios made from your original + Acer site update.
              thank you, it worked with my laptop
              • Blackam8899
                • Sep 2020
                • 44
                • Rosario
                #68
                Hi, can someone clean my BIOS? The problem is that it doesn't detect the keyboard. I tried two and neither of them worked, only the power button. I tried other BIOSes and when I put them in, the keyboard and mouse stop working. Thank you very much.
                ACER E5 757
                DAZAAMB16E0 REV E
                MODEL: ZAAX32​
              • vince2746
                • Mar 2023
                • 8
                • philipines
                #69
                hi pls help with this laptop no display..
                ACER ASPIRE E5-575-38UM
                BOARD ID : DAZAAMB16E0 REV:E
                MODEL : ZAAX32 / N16Q2
                SN : NXGE6AA018648025497600
                SNID : 6400954576
                • shamaltech
                  • May 2023
                  • 102
                  • Sri Lanka
                  #70
                  I have this Acer E5-575 Laptop of my customer.
                  The problem is it doesn't detect USB Mouse and Keyboards.
                  But USB flash drives, External HDDS are working fine.
                  When I connect a USB Mouse or Keyboard, windows popup the error "USB Not Recognized
                  The last USB device you connected to this computer malfunctioned, and Windows does not recognize it.​"
                  I tried with different OS , flash BIOS but same problem.
                  Any help?
                  • shamaltech
                    • May 2023
                    • 102
                    • Sri Lanka
                    #71
                    I have an Acer E5-575
                    i3-7th gen laptop
                    The issue is it's not detecting any external Mouse or Keyboard.
                    USB pendrives are working.
                    Touchpad and Laptop keyboard also working.
                    I tried with another Bios but the issue is same.
                    Do you know any solution for that?
                    • peste
                      • Dec 2016
                      • 12811
                      • ROMANIA
                      #72
                      i3-7th gen laptop
                      if it's not a bios problem, move the discussion to the main forum... maybe someone will help you there..
                      • shamaltech
                        • May 2023
                        • 102
                        • Sri Lanka
                        #73
                        How can I post in the main forum bro ?
                        • peste
                          • Dec 2016
                          • 12811
                          • ROMANIA
                          #74
                          make a new topic here and post...
                          https://www.badcaps.net/forum/troubl...mobile-devices
                          • shamaltech
                            • May 2023
                            • 102
                            • Sri Lanka
                            #75
                            Thank you.
                            I'll Try.
                            • lucky_tv
                              • Nov 2024
                              • 4
                              • Bulgaria
                              #76
                              Hi, can you please help me with working BIOS?
                              Acer Aspire E5-575, DAZAMB16L0, rev:E, model ZAA x32
                              s/n NXGDXEX0166522516C7600
                              SNID:65215191676
                              It is my daughter laptop, and make DIS to UMA by removing mosfets and inductance because was not been sure Nvidia n16s is work properly give me 11ohms on multimeter,
                              but still not have screen on machine and on VGA, so thing may be BIOS wrong. All voltages are Ok, laptop is switch on, fan is work when get little hot but no screen.
                              Attached is downloaded BIOS from laptop.
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11738
                                #77
                                SNID:65215191676
                                Aspire E5-575G
                                • lucky_tv
                                  • Nov 2024
                                  • 4
                                  • Bulgaria
                                  #78
                                  Originally posted by hoaca388
                                  Aspire E5-575G
                                  Thanks, but unfortunately bot are not working for me!
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11738
                                    #79
                                    Then your hardware is bad.
                                    • shamaltech
                                      • May 2023
                                      • 102
                                      • Sri Lanka
                                      #80
                                      Aspire E5-575G
                                      This model turns on with Intel Graphics.
                                      So the display not coming maybe a problem with your processor.
                                      • EbrahimSiami
                                        Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                        by EbrahimSiami
                                        I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                        **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                        **What I have tried so far:**
                                        1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                        07-02-2025, 02:31 PM
                                        ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                        This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-12-2024, 03:28 PM
                                        ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                        This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-12-2024, 02:30 PM
                                        ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                        This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                        ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                        This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
