Lenovo ThinkPad S5-S540 - VIUS6 LA-A171P BIOS
  • essaadi
    • May 2016
    • 38
    • KELAA
    I need bios dump for this computer. Any one have the files please.
  • zenny95
    • Aug 2017
    • 28
    • romania
    Re: Lenovo ThinkPad S5-S540 - VIUS6 LA-A171P BIOS
    backup bios
    • acshud
      • Sep 2017
      • 106
      • romania
      hello.i need to bios for s540.here it's my dump
      • acshud
        • Sep 2017
        • 106
        • romania
        i write bios download from here but it's very slow.takes more that one hour to install win 10
        • hoaca388
          Badcaps
          • Jan 2022
          • 11738
          s540
          Mį»i khoįŗ£n quyĆŖn góp cho badcaps đều được hoan nghĆŖnh, hĆ£y nhįŗ„p vĆ o liĆŖn kįŗæt nĆ y Ä‘į»ƒ quyĆŖn góp. Cįŗ£m Ę”n tįŗ„t cįŗ£ những ngĘ°į»i į»§ng hį»™----------------------------------------------------------------------------------------------------------------------------------------------------------------
          • acshud
            • Sep 2017
            • 106
            • romania
            not work for me.after bios setting,not booting and shutdown.i can't boot from usb and ssd
              • 20914
              Try this one
              • acshud
                • Sep 2017
                • 106
                • romania
                no.not work.i enter bios,make settings to boot and shutdown.thx
                  • 20914
                  Its a virgin bios.You can try to update to a newer version
                  https://download.lenovo.com/pccbbs/mobiles/gpuj30ww.txt
                  OS Optimized Defaults
                  - For Windows 10/8.1/8 64-bit Preload models [Enabled]
                  - For Windows 7 [Disabled]
                  https://pcsupport.lenovo.com/gb/en/p...me=BIOS%2FUEFI
                  • acshud
                    • Sep 2017
                    • 106
                    • romania
                    with first bios(old version) work but it's very slow.i update from lenovo site with ultimate version and stuck.after update i enter bios,reset to default,make change to uefi only to boot from ssd and stuck.i can't boot from usb to reinstall win.i try to boot to ubuntu.nothing work.
                      • 20914
                      The problem isn`t with the bios then.
                      • acshud
                        • Sep 2017
                        • 106
                        • romania
                        he did the same with the bios he came to me.it's strage he work with old version and new version make to stuck
                        • acshud
                          • Sep 2017
                          • 106
                          • romania
                          i discover problem.i have short circuit on U5302(TI R8966).bios work ok.thx
                          • bitfreak
                            • Jan 2023
                            • Slovenia
                            thanks
                            your bios save my ThinkPad S5-S540
                            • Joluvillas
                              Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                              by Joluvillas
                              Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                              06-18-2024, 10:35 PM
                            • 1g0r
                              Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                              by 1g0r
                              First, the data in brief:
                              Manufacturer: Lenovo
                              Model: ThinkPad L15 G3 21C3-0016GE
                              motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                              IC Bios 1: MX77L25650F
                              IC Bios 2​: MX25L25673G
                              EC Chip: NPCX997KAABX
                              So far I've been a silent reader, but now I need your help
                              I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                              I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                              The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                              01-18-2025, 02:39 AM
                            • akwky
                              by akwky
                              Hi!
                              04-14-2025, 01:56 PM
                            • AHmad_Salal
                              Need BIOS Dump/ROM for Lenovo Thinkstation p500
                              by AHmad_Salal
                              Hello all,
                              I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                              11-28-2023, 05:28 AM
                            • hyperwood
                              [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                              by hyperwood
                              I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                              The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                              I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                              āœ… What I need:
                              • A working 2MB BIOS dump
                              • Matching NM-E471 Rev. 2.0, e.g. JY575
                              06-25-2025, 02:28 PM
