ME BIOS cleaning
  • myth77
    • Feb 2017
    • 380
    • Croatia
    ME BIOS cleaning
    I have this laptop who had some short in power lines and bios failure.I repaired short and i found some bios dump on the internet..and laptop would start..but with problems...the bios logo would turn on after 15 seconds or more...and it wouldnt install graphic card drivers (not recognised) so in bios i had only basic display adapter.
    So i used Intel ME/TXE Injector to clean ME region. i have to mention that this is my first time to clean ME region. So i picked first Suitable ME version that program displayed (but not the same number as my BIOS ME version).
    Now everything is ok, bios logo is up in 2 seconds, graphic card drivers installed...but one problem ...Intel Management Engine Interface is showing mark ! with error Code 10. i tried to install few other drivers...but after 30 seconds it goes back to error code 10. And i have to mention that i didnt have this error on not cleaned BIOS (that one with problems above).
    So, what am i doing wrong? Did i have to use ME version with exact number as BIOS (even though the program is saying that others are suitable also) Or something else?
    thx
    • 22276
    Re: ME BIOS cleaning
    You need to reinstall the windows ME driver .Get the driver from the laptops support page or use the latest from win-raid https://winraid.level1techs.com/t/in...ols-2-15/30719
    • myth77
      • Feb 2017
      • 380
      • Croatia
      i did install Intel Management Engine Interface driver from laptop support page and again code 10 error was 30 seconds off then showed again in device manager..
      • piernov
        • Jan 2016
        • 4439
        • France
        I don't recommend using this method to clean ME region since it doesn't keep the configuration set by the manufacturer. Better use Intel FITC. Follow win-raid tutorial (or some Youtube video…)
        You can also try
        Code:
        fptw64 -greset
        Using Intel FPT.
        Also it could be that you used an incompatible version. Report MEAnalyzer for both the original dump and the cleaned dump.
        • myth77
          • Feb 2017
          • 380
          • Croatia
          ORIGINAL:
          CLEANED:
          original bios attached
          • piernov
            • Jan 2016
            • 4439
            • France
            9.0.30.1482_1.5MB_PRD_RGN.bin is available so use that one instead.
            • myth77
              • Feb 2017
              • 380
              • Croatia
              yeah, that did the trick...thx. But... when i installed it...everything was ok except when try to install graphic driver....error no compatible hardware detected...first i tried to reinstall chipset driver...but still same errorr...then i flashed bios...and finally gpu detected and driver installed...For now everything seems to be in working order...
              Oh, one more thing, probably you are right and in the future i should use intel FITC for cleaning ME, but can you send me some youtube link on how to?
              Thank you!
              • riko 656
                Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                by riko 656
                I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                Laptop Model:
                • Model: Lenovo Legion Slim 5 16APH8
                • GPU: NVIDIA GeForce RTX 4070
                • Main BIOS chip size: 32MB
                • VBIOS chip size: 16MB
                Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                What I Have Tried So Far:
                1. I
                11-04-2025, 05:14 AM
              • macabook
                by macabook
                🧩 Initial Issue
                07-24-2025, 02:17 PM
              • cr4zychriss
                by cr4zychriss
                • Rebrand: PC Specialist
                11-14-2025, 04:04 PM
              • pirati
                by pirati
                10-27-2025, 04:20 PM
              • iZakre
                HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                by iZakre
                Hello everybody!
                To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                The thing is that I had installed TeamViewer and could log into the computer...
                02-19-2023, 02:27 PM
