password remove Lenovo T560
  • basic
    • Oct 2017
    • 229
    • 86357289244
    Friends i need passsword remove from this model
    lenovo t560
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: password remove Lenovo T560
    Password in EC not BIOS.
    • basic
      • Oct 2017
      • 229
      • 86357289244
      How to remove now in Ec password !!?
      • Nico Latour
        Banned
        • Sep 2019
        • 52
        • france
        T560 has no ec chip password stored in mec chip.
        can unlock 2 ways
        1 with dxe driver (you find manual and dxe driver on forum here)
        2 read mec chip with svod 3 and clean password area
        • imranromi
          • Jan 2015
          • 1288
          • Pakistan
          can unlock 2 ways
          If i chose 2nd option then cannot edit Dmi information like serial number or UUID info always error or tool cannot support this laptop better i suggest find dxe driver and solve i better option
          • fyaagoub
            • Dec 2016
            • 269
            • maroc
            yes imranromi best way to disable the password in lenovo is to patch the bios and after to generate the hardware id with a key
            • Nico Latour
              Banned
              • Sep 2019
              • 52
              • france
              with svod you can reset password in mec (but risk) best way unlock patch with dxe driver, after unlock use lenovo uuid tool (boot from usb) then edit serial etc etc
              (the dxe driver is allready post on this forum, and when you decompiler the patch you dont need a key!)
              • Pferd5
                • Mar 2018
                • 68
                EC (with MEC) programming methode is very risky and involes soldering several very tiny resistors while soldering to very narrow traces (testpoints if you're lucky). So this is nothing you can do in 5min.
                BTW: All this TPM and multiple location stuff that is claimed on some sites is BS.
                Password in the secret area (mostly 2kb) is stored on the last "page" in the EC.
                • Nico Latour
                  Banned
                  • Sep 2019
                  • 52
                  • france
                  svod is not dangerous if you know what you are doing, and if you can do a little soldering you are not at risk, it is true that there is a small piece in mec reserved for certain settings, but with the latest update software (from svod 3) this is not problem! however I always recommend the dxe driver because then you don't have to solder and you don't have to program
                  • teto8485
                    • Nov 2016
                    • 64
                    • egypt
                    lenovo thinkpad t560 type 20fh
                    bios locked i need to unlock it plz
                    s/n R9-0KM3XL 16/05
                    LSZ-2 MB 15202-2
                    448.06D10.0021
                    • corona100
                      • Mar 2020
                      • 145
                      • U.S.A
                      Re: lenovo thinkpad t560 type 20fh
                      "Instructions for use"
                      Remove all battery and CMOS battery
                      press F1 to enter setup: password 1234
                      wait 20sec or more.
                      Enter any ID to hardware Id.
                      Press 2x space bar when asked.
                      Turn off the computer.
                      and restore your original bios .
                      Next time share your dump to get a clean dump
                      • teto8485
                        • Nov 2016
                        • 64
                        • egypt
                        thank u bro and this is the dump
                        • teto8485
                          • Nov 2016
                          • 64
                          • egypt
                          the unlock t560 patch give me five beep and cant open data
                          • prasad3030
                            • Oct 2015
                            • 11
                            • India
                            I programmed mec with fresh file but password not gone. and where the bloody password will store
                            • bouvierj
                              • Jul 2021
                              • 6
                              • France
                              Hello everybody, I have a Lenovo Thinkpad T560 6th gen and I would like to activate 'boot from usb' option in Bios but it is blocked with a supervisor password.
                              Can you help to bo the necessary steps?
                              Nico Latour, it seems you are French, can you help by contacting me if you see this mesage?
                              • Maxpower3
                                Bad Veteran
                                • Feb 2018
                                • 1164
                                • France
                                patch ok on this model
                                need read bios with programer
                                https://www.badcaps.net/forum/showthread.php?t=87588
                                • bouvierj
                                  • Jul 2021
                                  • 6
                                  • France
                                  Thanks a lot Maxpower. What do you recommend as programmer?
                                  And do you recommend also SOIC8 clips?
                                  Other question : I read on different forums that some Lenovo Thinkpads could be unlocked only by a shortcut between pin5 and 6 of the Eeprom at startup. Could it be possible for me?
                                  Thanks for help
                                  • Maxpower3
                                    Bad Veteran
                                    • Feb 2018
                                    • 1164
                                    • France
                                    Thanks for help
                                    I don't like clips, programming I use tl866 works very well for that
                                    Do not bypass pins 5 and 6 of the eeprom !!!! this is reserved for models with 24rf08
                                    • bouvierj
                                      • Jul 2021
                                      • 6
                                      • France
                                      Ok thanks.
                                      So you need to unsolder and solder 2 times ?? Seems difficult for me...
                                      And what about ezp2019 as programmer for little budget?
                                      • bouvierj
                                        • Jul 2021
                                        • 6
                                        • France
                                        Any help please?
