HP Mini bios bin file
  • bryanpoints
    • Aug 2017
    • 56
    • Philippines
    hi need bios dum hp mini 110-3730nr
    thanks
  • bryanpoints
    • Aug 2017
    • 56
    • Philippines
    Re: HP Mini bios bin file
    hp mini 110-3730nr
    p/n 010153h00-388-g
    • on/off
      • Oct 2016
      • 333
      • Indonesia
      Re: HP Mini Schematic
      thanks
      Bios request should be here, https://www.badcaps.net/forum/forumdisplay.php?f=40
      Please remember for next problem. For reason to organize all threads.
      I'm too lazy to search ( i think foxconn edward bios dump present on this lovely forum)
      Anyway, try it. not tested, from official update.
      If you have issue when extract it, try 7zip.
      Good luck
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • m1ch43lzm
        by m1ch43lzm
        Hi everyone
        09-06-2025, 05:47 PM
      • Forest79
        by Forest79
        07-23-2023, 07:39 AM
      • maanee11
        Help to get Lenovo BIOS bin file for Thinkpad T560
        by maanee11
        Hello Everyone,
        I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
        https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
        In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
        05-15-2022, 11:59 AM
      • hamdykl
        I need bios file to HP 8000 mini tower
        by hamdykl
        I need bios file to HP 8000 mini tower. i flashed bios IC and the
        MB working good but
        Lan not working i need bios file backup from MB to re-fash it on IC
        11-26-2023, 11:31 AM
