Hp 14-ax010nr need working bios and ec
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Hi friends, I need a working bios Main and EC for this HP 14-AX010NR
    BOARD IDA0P9MB16D0 REV: D MODEL: 0P9 please
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: Hp 14-ax010nr need working bios and ec
    anyone can share a working bios and ec please
      • 21197
      https://www.laboneinside.com/tag/da0p9mb16d0-bios-bin/
      • String2016
        • Nov 2015
        • 2238
        • philippines
        not working still the same issue turns on lights present but no display. i have uploaded the original main and ec
        • String2016
          • Nov 2015
          • 2238
          • philippines
          i tried also the bios and ec on vinafix site but still the same issue no display check voltages vcore is present 3v and 5v on grey coils is present
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • JDC
            by JDC
            ONN 100012588
            Long answer:
            07-15-2022, 07:39 AM
          • DynaxSC
            Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
            by DynaxSC
            I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
            I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
            Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
            Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
            05-04-2025, 12:08 PM
