Lenovo ThinkPad T540P LKM-1 SWG2 MB 12308-2 48.4L016.021 PASSWORD
  • Andreasbest
    • Aug 2014
    • 1196
    • Hellas ( Greece )
    Hello.
    A customer wants to bring me 3x Lenovo T540p with locked BIOS.
    Once I unlocked a T540p but it was a huge procedure that required completely tear down of whole laptop, took me around 2 hours just for one device.
    Is it possible to extract the password from the locked BIOS file?
    It will be much easier to unlock them this way.
    Thank you!
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1356
      • France
      not possible extract password
      look if debug connector is available for try use bypass
      Wistron Kome-1 SWG2 LKM-1 SWG2 MB 12308-2
      • Andreasbest
        • Aug 2014
        • 1196
        • Hellas ( Greece )
        I was afraid of it.
        I tried AMIDecryptor but works until 3rd Gen.I'lI check for the lps bus location, I hope is easy to reach.
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1356
          • France
          Originally posted by Andreasbest
          I was afraid of it.
          t540p vs w540
ID:	3669490 ​ ​
          found on u39 and DB2 too​
          ​​ Click image for larger version
          • nuno_nunes
            • Jul 2025
            • 10
            • Portugal
            Click image for larger version  Name:	image.png Views:	113 Size:	129.9 KB ID:	3669489
            t540p vs w540
            Click image for larger version  Name:	image.png Views:	79 Size:	1.14 MB ID:	3669490
            ​​ Click image for larger version  Name:	image.png Views:	77 Size:	167.9 KB ID:	3669491
            Click image for larger version  Name:	image.png Views:	78 Size:	53.3 KB ID:	3669492 ​
            I need help to thinkpad t540p
            • Andreasbest
              • Aug 2014
              • 1196
              • Hellas ( Greece )
              #26
              T540p is super easy for EC bypass, done 40 yesterday in only 5 hours, LPC also is super easy to access, just remove the wlan/wwan cover and it's right behind the wlan card, just unscrew it and you see it (DB2).
              Short any LPC with GND for 1 sec when Lenovo logo appears and press F1, it will enter BIOS, then press 2 times blank code on Administrator password to disable it, ctrl alt del and you are done.
              • nuno_nunes
                • Jul 2025
                • 10
                • Portugal
                #27
                Could you please make a video if possible?
                  • 22012
                  Different model but you`ll get the idea https://www.youtube.com/watch?v=Xw28inqitKk
                  • nuno_nunes
                    • Jul 2025
                    • 10
                    • Portugal
                    #29
                    I don't understand this pin motherboard? U39 to db2 ou db1
                    i try pin to u39 to db2 and not work
                    • Andreasbest
                      • Aug 2014
                      • 1196
                      • Hellas ( Greece )
                      #30
                      ANY of these 4 pins (not all, just pick one) to the GROUND!
                      • nuno_nunes
                        • Jul 2025
                        • 10
                        • Portugal
                        #31
                        Is not easy
                        • Andreasbest
                          • Aug 2014
                          • 1196
                          • Hellas ( Greece )
                          #32
                          Where do you stuck?
                          • nuno_nunes
                            • Jul 2025
                            • 10
                            • Portugal
                            #33
                            Where do you stuck?
                            I tried with the images you have of the board with the points and nothing and that's why I'm not going to fix this because I don't want to destroy the PC.
                              • 22012
                              Do you have an EC programmer ? . https://www.badcaps.net/forum/troubl...79#post1703979
                              • nuno_nunes
                                • Jul 2025
                                • 10
                                • Portugal
                                #35
                                This programmer of bios?
                                • Andreasbest
                                  • Aug 2014
                                  • 1196
                                  • Hellas ( Greece )
                                  #36
                                  A programmer like CH341A, very cheap. With Lenovo Autopatcher you can disable password with it, the BIOS chip is under the heatsink, thus means you have to disassemble the whole laptop, done it once and i decided there will be no second time.
                                  • Maxpower3
                                    Bad Veteran
                                    • Feb 2018
                                    • 1356
                                    • France
                                    #37
                                    I'm glad it helps you
                                    • Andreasbest
                                      • Aug 2014
                                      • 1196
                                      • Hellas ( Greece )
                                      #38
                                      First time i tried it in so old laptop and the only reason i tried it is because before a month i opened one for Autopatcher, bios chip was so deep in this model that i had to completely dismantle the whole laptop, motherboard and even the heatsink (chip in underneath) plus the T540p dump for some reason is not compatible with Autopatcher and produces error at the end making the patched backup unusable, only the patched dump on this link works and then i write back the original.
                                      Fun fact: probably because it's too old, the short never produced any error (no fan detected, no mouse detected, no kb detected etc.) so it enter the bios with 1 or 2 tries, extremely easy.
                                      For 10th time thank you for it Max!
                                        Lenovo ThinkPad T540p Grade Barga1n+ Notebook T Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad T540p Grade Barga1n+ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T540p Grade Barga1n+ boardview and T540p Grade Barga1n+ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        09-06-2024, 09:01 AM
                                      • Maxpower3
                                        Brand name and Model Type for Lenovo error 2202 product name is invalid
                                        by Maxpower3
                                        Info for error 2202 LenovoThinkPad models and type
                                        Extract from ThinkPad Maintenance Utilities Configuration File
                                        plnsrv.ini Version 1.01
                                        Some information that may be useful
                                        There must also be missing models, add them to the list if you know of any.
                                        Code:
                                        brand name
                                        20B1=ThinkPad Edge E445
                                        20B2=ThinkPad Edge E545
                                        20BC=ThinkPad Edge E145
                                        20BM=ThinkPad X140e
                                        20BL=ThinkPad X140e
                                        20A3=ThinkPad X230s
                                        20AH=ThinkPad X230s
                                        20AK=ThinkPad X240s
                                        20AJ=ThinkPad X240s
                                        02-21-2024, 10:27 AM
                                        Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                        09-06-2024, 11:40 AM
