DELL latitude 7390 bios dump
  • struart
    • Aug 2022
    • 39
    • Poland
    #121
    kalilinux25
    Look like its not working.
    5 restarts no display then shutdown and stays like that.
    • jackx
      • May 2020
      • 221
      • casa1
      #122
      hello help password dell 227H5S2-E7A8
      https://beta.bios-pw.org/ NOT WORK
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        #123
        Originally posted by struart
        kalilinux25
        try this , from a working board then remove bios region with fresh and clean me
        • struart
          • Aug 2022
          • 39
          • Poland
          #124
          kalilinux25
          Looks like theres another level of problem with this unit.
          With this DUMP keyboard lights up fans are up, its restarting 5 times after 5 seconds (consuming from 0.100-0.300 A of current on lab PSU) each and then turns off and stays like that (consuming 0.032 A on lab PSU).
          Probably bigger hardware problem.
          Thank you for help anyway
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            #125
            kalilinux25
            Probably a bigger hardware problem.
            Thank you for your help anyway
            Yes that will be high possibly that can cause this type of issues
            • hcx
              • Sep 2024
              • 10
              • Europe
              #126
              Hi, I'm trying to fix not working bios dump. What are the bits changed in Descriptor region:
              0x131 6D -> 00
              0x134 01 -> 00
              0x202 F0 -> 40
              How did you get MFS partition with OEM Configuration?
              • abdelilahocs
                • Nov 2018
                • 119
                • morroco
                #127
                ​daz20 la-f311p rev 2.0 (a01)
                Does anyone has dump of this model pls
                • peste
                  • 13200
                  • ROMANIA
                  #128
                  post the S/T, the original bios of the laptop,, etc.
                  • abdelilahocs
                    • Nov 2018
                    • 119
                    • morroco
                    #129
                    I tested this bin and it works
                    Originally posted by imranromi
                    Re: DELL latitude 7390 bios dump
                    Try this and post results.
                    thanks a lot
                    • hcx
                      • Sep 2024
                      • 10
                      • Europe
                      #130
                      My laptop stop working after bios update from 1.38 to 1.39. Caps Lock is on for 30 seconds and noting happen. Power button is on all the time. Display test, CMOS reset (press Power button for 25s) are working. Missing RAM is detected.
                      I was trying to fix bios dump but nothing changed.
                      Can someone check dump and fix?
                        SMDFlea commented
                        Editing a comment
                        Forum rules, post the service tag please .
                    • hcx
                      • Sep 2024
                      • 10
                      • Europe
                      #131
                      S/T is in dump at address:
                      - 0x8516CF
                      - 0x8596CF
                        • 21451
                        - 0x8516CF
                        - 0x8596CF
                        I know how to find a service tag in the bios.
                        RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
                        You MUST:
                        • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                        • hcx
                          • Sep 2024
                          • 10
                          • Europe
                          #133
                          You MUST:
                          S/T: 69Q9433 Board: DAZ20 LA-F311P Rev: 3.0 (A02)
                          • kalilinux25
                            • Mar 2018
                            • 2089
                            • ZAMBOANGA SIBUGAY
                            #134
                            Here is your bin added service tag please give feedback
                            • hcx
                              • Sep 2024
                              • 10
                              • Europe
                              #135
                              Thanks, your bin is working!
                              What was wrong with my fix?
                              I can read in the bios events that upgrade from v1.38 to v1.39 was successful. So what was wrong?
                              After update to 1.39 same issue again. Laptop not starting.
                              • kalilinux25
                                • Mar 2018
                                • 2089
                                • ZAMBOANGA SIBUGAY
                                #136
                                maybe clean me and bios region was not replaced
                                • hcx
                                  • Sep 2024
                                  • 10
                                  • Europe
                                  #137
                                  It appears that bios v1.39 does not work on this unit.​
                                  • kalilinux25
                                    • Mar 2018
                                    • 2089
                                    • ZAMBOANGA SIBUGAY
                                    #138
                                    what those the bios now is shwoing? v1.38 to v1.39 ?
                                    • hcx
                                      • Sep 2024
                                      • 10
                                      • Europe
                                      #139
                                      Using the bin file from you I have version v1.38.​ And after updating to v1.39 same issue occurs.
                                      • sezpimp
                                        • May 2023
                                        • 9
                                        • Poland
                                        #140
                                        I have a problem with the password on the bios. Can someone help me?
                                        DAZ20 LA-F312P rev.1.0 Dell 7390.
                                        Service Tag: HGFWJR2
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                          DELL Latitude 7390 Notebook 7000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 7390 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7390 boardview and 7390 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7390...
                                          09-06-2024, 12:20 PM
                                          DELL Latitude 7390 Hybrid (2-in-1) 7000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 7390 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7390 boardview and 7390 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                          09-06-2024, 11:14 AM
