Panasonic CF-54 Bios Password
    Re: Panasonic CF-54 Bios Password
    Originally posted by freeflight View Post
    I got it. Looking through other bios dumps in this thread, I saw that the mac address is often found here 0x1000 and here 0x2000.
    I copied these lines of code from the backup bios and it didn't change anything. Then I realized that the problem was probably with the Windows system. It had somehow memorized the Mac's address and didn't change it. After reinstalling Windows, the problem was solved, and the Mac address changed to the one in the original bios.
    Changing only the MAC address bytes sometimes does not work, you have to copy the whole Gbe region. It can be extracted as-is with UEFITool, it shows the start address and file length in the info column on the right side.
      Thank you for the information
        Originally posted by hoaca388 View Post
        You must resolve the issue of hardware damage that arises.
        was able to fix the hardware issue. Change the screen and it worked. Thanks for the help.
        I also try to remove the bios passward for another laptop. Any one, please confirm if the bios password is remove. Attaching both bins.
          Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
            Picture attached for serial number.
              Anyone has a bios dump for cf-54mk1?
              model number is CF-54cy003ee
              serial number 6atca40941
              someone tried to remove password and they messed original dump.
                nope, you missed a spot
                all donations are welcome,
                  Thanks for the reply. I was able to remove it myself
                    can someone help me to remove password? from cf-54mk1?
                      serial number?
                        sorry, forget it, I mentioned earlier above
                          upload original bios, not your attempt to clear password.
                            Unfortunatelly this is my only file what I have. I got laptop without bios file. I asked earlier If someone has a correct file but did not get answer. Managed to purchase a file online but it is password protected. This is the only file that boot the laptop. Any help would be appriciated
                              I have a Panasonic CF-54BY009TG with password. There is only one area after "AMITSESetup" to clear but it didn't clear the password. Can you help me?
                              Serial number is 7CTCA19400.
                              Thank you!
                                Originally posted by flooodi View Post
                                hello,
                                i have a panasonic cf-54by009tg with password. There is only one area after "amitsesetup" to clear but it didn't clear the password. Can you help me?
                                Serial number is 7ctca19400.
                                Thank you!
                                wwwwww
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                  unfortunatelly this is my only file what i have. I got laptop without bios file. I asked earlier if someone has a correct file but did not get answer. Managed to purchase a file online but it is password protected. This is the only file that boot the laptop. Any help would be appriciated
                                  wwwwwww
                                    keep getting checksum error after verifying. Only power light flashes and does not boot
                                      once more
                                        wwwwww
                                        Thank you for your answser hoaca388!
                                        Tested but I still have bios password active.
                                        Best Regards!
                                          This solution worked for me.
                                          Thank you!
