Hp 840 G4 with Touch Screen Bios Need
  • Murtaza527
    • May 2018
    • 262
    • Malaysia
    i have tried many bios files from this website but not succeed
    display come but touch screen not working even don't have function in bios also if someone have 840 G4 with touch screen please read bios and share with me
    Model : 840 G4
    Mother Board : 6050A2854301-MB-A01
    thanks in advance
    • 22276
    Re: Hp 840 G4 with Touch Screen Bios Need
    Have you installed the Intel Serial IO Driver, look in device manager for an I2C device . https://support.hp.com/gb-en/drivers...Id/ob-216288-1
    • Murtaza527
      • May 2018
      • 262
      • Malaysia
      thank you very much after installing that driver touch is ok now thanks agian
      • mhdabboud
        • Mar 2015
        • 19
        • Syria
        Hi my friend I need bios for this model but it has a touch screen
        I flash a bios bin and delete the orginal one
        but the touch sceen didnt work after that
        can you help me with this please
        Model : 840 G4
        Mother Board : 6050A2854301-MB-A01​
        • cr4zychriss
          by cr4zychriss
          • Rebrand: PC Specialist
          11-14-2025, 04:04 PM
        • mitchw
          HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
          by mitchw
          Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
          After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
          After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
          I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
          04-29-2025, 03:45 PM
        • BlueNitesFire
          I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
          by BlueNitesFire
          So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
          03-08-2025, 03:49 PM
        • Technodoc
          ASUS G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
          by Technodoc
          Asus laptop G614JZ-N3012W Rog Strix with i7
          Mainboard G634J-PMV-VGT
          6050A3441302-MB-A01
          2023-02-10
          Power button works okay....power light goes on
          Red "bottom" leds go on
          Charging led works
          Fans do not spin, capslock key does nothing, screen stays black
          I would like to program the bios again, to rule out a corrupted bios.
          However I run into a size error
          The bios chip is a Winbond 25R256JVEN
          Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
          02-24-2025, 04:46 AM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
