asus vn247h bios dump needed
  • hadi20
    • Apr 2019
    • 3
    • united kingdom
    hello everyone. my asus vn247h monitor wont connect to GPU signal but it connects to DVB receiver signal and it show DVB receiver channels. i tested it with many GPUs with no success. my repair man said that problem is my monitor BIOS and it needs a healthy BIOS. can you provide me with this BIOS?
    thank you.
  • ArkzG
    [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
    by ArkzG
    Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
    What I currently have available:
    - Model: FA506NF (2021)
    - BIOS chip: GD25LQ16 (16Mbit/2MB)
    - Tools: CH341A programmer ready to use
    Does anyone have either a clean 2MB .bin dump of this model,...
    09-26-2025, 09:34 PM
  • mkdj
    by mkdj
    Dear all,
    10-19-2025, 04:41 AM
  • kodox
    Asus ExpertBook B1400CB Bios Dump Needed
    by kodox
    need original bios dump, original bios has flashed by other technician before me.
    attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
    unit info:
    Model: Asus ExpertBook B1400CBA-0711A1235U
    S/N: R6NXNZ006657238
    CN: 7F6F
    Mainboard Code: B1500CBA R2.1...
    08-16-2025, 12:20 PM
  • pirati
    by pirati
    10-27-2025, 04:20 PM
  • DynaxSC
    by DynaxSC
    06-14-2024, 03:49 PM
