asus vn247h bios dump needed
  • hadi20
    • Apr 2019
    • united kingdom
    hello everyone. my asus vn247h monitor wont connect to GPU signal but it connects to DVB receiver signal and it show DVB receiver channels. i tested it with many GPUs with no success. my repair man said that problem is my monitor BIOS and it needs a healthy BIOS. can you provide me with this BIOS?
    thank you.
  • DynaxSC
    by DynaxSC
    06-14-2024, 03:49 PM
  • DynaxSC
    by DynaxSC
    11-17-2023, 10:56 AM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
  • TacticalFahrrad
    [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
    by TacticalFahrrad
    I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
    06-30-2025, 04:09 AM
  • vinaypundith
    Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
    by vinaypundith
    I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
    So, I'm looking for a BIOS dump for this machine - a 16MB one....
    08-03-2024, 12:32 PM
