Need bios & ec from BDL50 LA-D704P REV:4.0 for HP
  • piszpunta
    • Jan 2019
    • 260
    • poland
    Re: HP 15-be012tu bdl50 la-d704p rev 4.0
    after programming KBC https://www.badcaps.net/forum/showthread.php?p=892451 POST#11 pwr LED is on.
    I need KBC dump
      • 22109
      I need KBC dump
      Your bios i.d. BID is 081EC ,flash a clean bios from post #9 in this thread - https://www.badcaps.net/forum/showthread.php?p=739852
      Flash this EC extracted from that bios . If you still can`t boot the problem is somewhere else, check AD_ID the middle pin id .
      • piszpunta
        • Jan 2019
        • 260
        • poland
        thank you very much.
        everything works
        • mehdisfr
          • Jan 2017
          • 13
          • tunisia
          Re: Need bios & ec from BDL50 LA-D704P REV:4.0 for HP
          Here`s your bios,its a full bios extracted from the hp update with your win key added.
          everything works:مجموعة:
          • techcornertrip
            • Dec 2021
            • 9
            • philippines
            its working thanks bro. GODBLES
            • marcelohugo
              • Nov 2018
              • Argentina
              #26
              Need Bios dump AND KBC HP 15-be012tu
              MOTHERBOARD : bdl50 la-d704p rev 4.0
              CPU : SR2UW Intel i3-6006U
              GPU NONE ONLY INTEL
              KBC : ENE KB9022Q D
              MY ORYGINAL BIOS DUMP HERE
              • tyso
                • Dec 2018
                • 3
                • kenya
                #27
                Thanks it worked for me but with few seconds delay
                • geniusDoc
                  • Apr 2022
                  • Italy
                  #28
                  1.424 / 5.000
                  Risultati della traduzione
                  star_border
                  Hello, I apologize for my English but I am using a translator.
                  I'll explain my problem if someone with a good heart can help me.
                  Introduction I have an HP 250 G5 laptop, with a la-d704p rev.4.0 motherboard inside (not working due to power supply problems) I have recovered 2 similar cards on the internet but which should be compatible, both are la-d703p rev.3.0 , the two cards of which the retailers confirm to me are 100% working, but once mounted with both cards the caps lock flashes 3 times, the fan turns but the PC does not start with a black display. I tried to extrapolate with the CH341A programmer with CH341A Programmer v1.44 software the original bios and also enter some found on the internet but with some bios the flashes went from 3 to 1 and the fan turned on for a very short time, with others always the same problem of 3 flashes and the fan operated in a regular way. I am forced every time to unsolder the cip otherwise the programmer does not recognize it.
                  I hope I have succeeded in explaining my experiments in these lines, being a beginner, but I just like to experiment, I kindly ask if you can help me understand if I'm all wrong and if my reasoning is wrong.
                  I attach the original bios extrapolated from the cip of the original card and the bios of one of the two cards purchased from the internet.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12419
                    #29
                    HP 250 G5 Notebook PC
                    DMI : 210000h -> 210FFFh
                    Your BID : 081EF but you can try other.
                    • geniusDoc
                      • Apr 2022
                      • Italy
                      #30
                      thank you very much, as soon as I can I will try them all.
                      • metropolisystem
                        • Jan 2016
                        • 40
                        • Colombia
                        #31
                        thanks, its work perfectly
                        • fiagah
                          • Jan 2021
                          • Ghana
                          #32
                          Friends, my board BDL50 LA-D704P REV:4.0, stopped powering up after restarting it ten times, just because I ignore keyed in information like feature Byte, Build ID etc. after replacing KB9022Q D and programming it with EC bios.
                          pls help
                          • thanhthuong28786
                            • Aug 2018
                            • vietnam
                            #33
                            its working ok with me. thanks
                            • jeewantha
                              • Nov 2016
                              • 88
                              • Sri Lanka
                              #34
                              Need Bios dump
                              MODEL : HP 15-ay512TU
                              SERIAL : CND626BFZ4
                              MOTHERBOARD : BDL50 LA-D704P Rev : 1.0
                              CPU : SR2EY
                              GPU NONE ONLY INTEL
                              MY ORYGINAL BIOS DUMP HERE​
                              • peste
                                • Dec 2016
                                • 13747
                                • ROMANIA
                                #35
                                Originally posted by jeewantha
                                Need Bios dump
                                SERIAL : CND626BFZ4
                                CPU : SR2EY
                                GPU NONE ONLY INTEL
                                you have everything you need at post #29,,,081EC
                                • macabook
                                  by macabook
                                  🧩 Initial Issue
                                  07-24-2025, 02:17 PM
                                • cr4zychriss
                                  by cr4zychriss
                                  • Rebrand: PC Specialist
                                  Yesterday, 04:04 PM
                                • pirati
                                  by pirati
                                  10-27-2025, 04:20 PM
                                • Vesko356
                                  by Vesko356
                                  08-11-2023, 03:27 AM
                                • jbonavita
                                  by jbonavita
                                  Some issues
                                  Things I tried
                                  04-29-2025, 09:38 PM
